98 w900 keeps cutting out
Discussion in 'Kenworth Forum' started by irishluck09, Oct 5, 2022.
  1. irishluck09
    irishluck09 Light Load Member
    295
    182
    Nov 24, 2019
    W900 n14 cummins 13spd
    So we've been chasing this problem for a few months now.
    The truck rolls down the road alright but will just randomly cut in and out. I took a video (for sound) that will show kind of what's going on.
    We have recently replaced the main engine wiring harness, new fuel pump and fuel cutoff solenoid ( even though my truck doesn't use the solenoid to shutoff).
    But the truck still cuts in and out. Has a hard time pulling hills even when empty.
    We're possibly leaning towards the throttle pedal but im just not sure. Anything else could look at to figure this out?
    Links below are of the exhaust where you can hear the cutting in and out.
    https://youtube.com/shorts/8cClN1XpxhQ?feature=share
    https://youtube.com/shorts/y6JWfNUVqUw?feature=share
  3. Big Road Skateboard
    7,160
    40,557
    May 2, 2021
    What does your truck use if not using the fuel solenoid?
  4. ProfessionalNoticer
    2,941
    7,858
    Apr 25, 2021
    Are you able to replicate the issue while not driving the truck?
  5. irishluck09
    295
    182
    Nov 24, 2019
    No, it's only while driving unfortunately. Wether I'm empty, loaded or bobtailing.
    I can sit and revv it up with no cut outs though
  6. irishluck09
    295
    182
    Nov 24, 2019
    The ecm. I'm not exactly sure ehst it does but it's set through the ecm.
    I can take the wire off that solenoid and remove the guts out of it and the truck still shuts off
  7. blairandgretchen
    13,966
    76,798
    Dec 9, 2011
    South west Missouri
    Those scan guages are kinda handy for things like diagnosing dash readings and sensors - there’s a TPS reading on them that would verify the throttle position sensor while rolling.
  8. ProfessionalNoticer
    2,941
    7,858
    Apr 25, 2021
    Sounds like it needs some sort of load, even if just the weight of the truck. I'd be checking the fuel system for air. Maybe run some clear tubing in line with your main suction line long enough to see from the drivers window while driving. Look for bubbles. Or maybe find a dyno nearby and see if you can rent it by the hour. Of course if all else fails the dealer can handle all that too.
  9. irishluck09
    295
    182
    Nov 24, 2019
    Well we figured out the issue and it isn't one that I would have ever thought about it.
    Turns out the coolant level sensor had a wire exposed and was grounding out from touching one of the AC lines. Hasn't missed once in over a week now.
    Bean Jr., Opendeckin, lester and 2 others Thank this.
