A Flat Tire
Discussion in 'Questions From New Drivers' started by tumblin dice, Jul 25, 2014.
  1. tumblin dice
    tumblin dice Light Load Member
    201
    99
    Apr 18, 2014
    Jacksonville, FL
    The scenario: You leave a shipper with a full load on a late Friday. You thumped the tires before you left and they sounded good. Two hour later you stop at a rest area and thump your tires again. You find that one is waay low though its not excessively hot yet. There is a truck stop about 25 miles away. Weekend dispatch advises you to try and limp it to the truck stop. Would you comply knowing that you risk ruining the tire?
  3. HotH2o
    HotH2o Road Train Member
    4,100
    4,868
    Sep 23, 2012
    I'd go for it.
    Chinatown Thanks this.
  4. jbatmick
    jbatmick Road Train Member
    2,200
    2,512
    Dec 1, 2009
    hastings, Fl
    I would put it in gear and set sail.
    That is why I carry an air hose with me. Air up a leaking tire and head for the tire shop.
    fireba11 and "semi" retired Thank this.
  5. STexan
    STexan Road Train Member
    14,963
    29,160
    Oct 3, 2011
    Longview, TX
    Yep air it up if you can, if not, don't drive faster then about 55 to keep heat to a minimum, to the next truck stop, especially if your loaded heavy. These high summer temps will take a toll on low PSI tires trying to support a heavy load.
    gpsman and jbatmick Thank this.
  6. w.h.o
    w.h.o Road Train Member
    3,583
    4,094
    Jan 10, 2011
    Chicago, il
    I also carry an air hose for situation like this where im no where near a tire place or truck stop. Also i would just go for it.
  7. tumblin dice
    201
    99
    Apr 18, 2014
    Jacksonville, FL
    Hmmm......well I would be concerned that if I went for it and ruined the tire, that safety would want to write me up or something?
  8. Richter
    Richter Road Train Member
    4,090
    1,700
    Feb 13, 2012
    Philadelphia Pa
    Is it your tire or theirs? Id roll slow if they give the ok. A TPMS is not a bad investment since it tells you temps and pressure of all your tires allt he time
  9. w.h.o
    3,583
    4,094
    Jan 10, 2011
    Chicago, il
    well your title said flat but your post said low, low tire you won't ruined the tire. a flat tire different but you still can ride it to safety. 5-10 maybe 25 miles like you stated dependin how low or flat it really is
  10. VagabondTrucker
    VagabondTrucker Light Load Member
    81
    30
    Jun 28, 2014
    Imho, if dispatch tells you to limp it there, it is on them. Just make sure you have that in a qualcomm or text msg format so they cant say they told you not too. I lost an outside drive tire(not blow-out) and FM told me to take it almost 50 miles to shop to fix it. I was fully loaded and checked it four times on the way there to make sure it wasnt shredding. Got there, they plugged it, reset it and it has been fine since.
  11. jbatmick
    2,200
    2,512
    Dec 1, 2009
    hastings, Fl
    A road service call to a rest area to fix a flat could be 3 / 4 hundred bucks. It is worth the chance.
    STexan Thanks this.
