a question for Thermo King s600
Discussion in 'Refrigerated Trucking Forum' started by hendrix69, Sep 21, 2025.
  1. hendrix69
    hendrix69 Bobtail Member
    44
    7
    Jun 4, 2025
    Hi fellows, why the unit doesn’t do defrosting? Load is fries at -10. Drain hoses are clean no dirt.but water tray got frozen always. Even if i press the defrost button for manually it’s not doing defrosting because there is no water coming out from the drain hoses. Open for any advice.. thank you in advance.
  3. Buckeyes614
    Buckeyes614 Light Load Member
    151
    154
    Jan 22, 2014
    You have to go inside the trailer and remove the bulkhead which covers the evaporator, when the defrost kicks on and ur evaporator coils melt the ice, the water drains down to a water collector below the evaporator, the water collector has two holes which ur hoses are connected to, clean and remove all the debris from the water collector and you should be good to go, these gets clogged if you don’t sweep out ur trailer.
