Ac makes a lake
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by mover man, Jul 8, 2020.
  1. mover man
    mover man Road Train Member
    1,698
    1,801
    Feb 21, 2010
    I no all AC drip water due to condensation. But mine drips A LOT. If the trucks parked on my left and right make a puddle, mine makes a creek.
    If theres makes a creek, mine makes a lake, etc..
    Mechanics at T/A is telling me that's normal. But that doesnt seem right to me. Why does mine drip 10x as much as everybody else?
    austinmike Thanks this.
  3. MM71
    MM71 Heavy Load Member
    760
    992
    Jun 28, 2008
    AZ
    Be glad it's working so good! If its not leaking from the evaporator, and leaking off the metal parts of the lines themselves. You could always insulate the lines.
    mover man, Rideandrepair and bzinger Thank this.
  4. Judge
    93,074
    Means you got a good A/C, I wouldn’t worry about, but don’t just be standing there, especially if the water is running by someones drivers door..
  5. uncleal13
    uncleal13 Road Train Member
    3,797
    6,299
    Apr 9, 2009
    Humboldt, Sk
    Depends on current environmental humidity level.
    mover man, baha, Rideandrepair and 2 others Thank this.
  6. Lazer
    Lazer Road Train Member
    1,850
    2,984
    Jan 22, 2017
    Consider your self blessed
    mover man and Rideandrepair Thank this.
  7. bad-luck
    bad-luck Road Train Member
    3,458
    6,381
    Nov 16, 2013
    Baltimore, Maryland
    Its condensation from the evaporator, its normal some trucks drip more than others. When It stops working then worry
  8. austinmike
    143,875
    My 94 Chevy poured water from the ac
  9. SmallPackage
    5,827
    18,679
    Dec 20, 2019
    Marion Texas
    My ‘99 FL would never drip on the ground it was either always flooding out on the passenger side floor board or the evap box drain was right over the exhaust pipe so it would steam it before it could hit ground.
  10. Rideandrepair
    17,580
    56,948
    Aug 8, 2015
    The more the better.
    mover man and austinmike Thank this.
  11. Hulld
    Hulld Road Train Member
    2,884
    6,568
    Oct 19, 2015
    Upstate NY
    The more humid it is inside the truck the more water from the drain outside.
    If you don’t run the AC on recirculate and are pulling humid outside air in to the cab you will have more water out the drain.
    Also if your cab is not well sealed ( or an air vent is open)and is leaking humid air in to the cab you will have more water out the drain.
