Advice on fighting a ticket for failure to obey sign.
Discussion in 'Ask An Owner Operator' started by steve2039, Sep 16, 2024.
  1. steve2039
    steve2039 Bobtail Member
    9
    12
    Sep 16, 2024
    Greetings!
    wasn’t sure where to post this and have read of similarities (but not quite the same) and wanted to see if anyone else has ever had this happen.
    I live in Georgia. Made a drop and was bobtailed. Due to an accident on a normal route, I went a different route back to my shop.
    On a side road leaving the drop, I turned right. Approximately 20 feet from the entry of the road, there was an unseen sign (trees, curve, etc.) that was unseen with a “36k gvrw” limit. Truck is under 36k by a Long shot. Also, this sign is 150 feet from another company’s terminal (the placement makes zero sense). the sign is also smaller than every other one in the county.
    Two miles away, I get stopped by local PD. I was issued a citation for “failure to obey sign” (not an overweight ticket). In Georgia, this is 4 points and treated the same as blowing a red light and COULD be a misdeameanor.
    Legally, the GVRW is over 36k. That isn’t the debate. However without a trailer, has anyone ever fought a similar ticket? PD never looked at GVW and this particular officer has made the news more than one time for the amount of “distracted driving tickets”.
    Attorney has been hired and the question isn’t whether or not I passed the sign.
    there’s really two pieces to it:
    1. is there a federal law for minimum requirements for gvrw signs? I’ve searched high and low because this signs in blind curve on a 45 road. Knowing where the sign is, you cannot see the sign until it’s too late. Everything I’ve read is not recent and has no specifics about setback or size.
    2. Could the argument be made that GVRW without a trailer would be nowhere near 36k?
    Siinman and blairandgretchen Thank this.
  3. steve2039
    9
    12
    Sep 16, 2024
    This is the literal sign in question. This image is from a video driving from the facing side. The fence is the drop point where I dropped and just past it, is the other terminal.
  4. bryan21384
    bryan21384 Road Train Member
    15,753
    34,337
    Sep 18, 2009
    Memphis, TN
    That's more of a question for your attorney. Good move to hire one since it's 4 points. In my mind, I'd say yes you could argue that. Just make sure you go into court with some sort of proof showing the weight if the vehicle, like a CAT scale ticket or something. Perhaps a pic of the vehicle identification label will work, it may have the weight of the vehicle as well.
  5. Diesel Dave
    9,706
    33,119
    Jan 20, 2010
    Hesperia, Ca.
    Go get a CAT Certified scale weight. Go to court and show your proof you’re under the limit. No need to pay an attorney for this long as you have the PROOF.
    Iamoverit, Siinman, steve2039 and 2 others Thank this.
  6. TX2Day
    TX2Day Medium Load Member
    612
    4,098
    Apr 24, 2023
    Texas
    Keep the attorney and get a cat scale ticket. Dot them "i's" cross those "t's".
  7. MAMservices
    MAMservices Medium Load Member
    597
    4,387
    Aug 9, 2021
    I know where you are comin from but sign says "Over 36000 GVWR", not how much the truck weighs. Just sayin, and cop prolly done it before.
  8. lual
    lual Road Train Member
    5,352
    9,775
    Oct 22, 2020
    SW Georgia
    Would also be great to know which county in Ga this is -- other drivers may go around problem area (& cop)....
    -- L
    TX2Day Thanks this.
  9. Long FLD
    Long FLD Road Train Member
    12,918
    54,214
    Mar 4, 2015
    Doesn’t matter what your truck actually weighs, the GVWR is probably between 50-60k.
    That said, yes there are regulations governing sign placement. There is a thread on this forum where a guy beat a ticket in AR because of placement.
    FHWA - MUTCD - 2003 Edition Revision 1 Chapter 2B
    Do some digging there and any other research you can do on the manual of uniform traffic control devices.
    TX2Day, Siinman, steve2039 and 3 others Thank this.
  10. blairandgretchen
    13,964
    76,789
    Dec 9, 2011
    South west Missouri
    Local cop is a prick.
    Fight it to the death.
    Call OOIDA, mention it to them.
    I’d also ask city council the reason for the sign being there.
    TX2Day, Siinman and Rideandrepair Thank this.
  11. steve2039
    9
    12
    Sep 16, 2024
    Gwinnett. 316 at Publix DC. Take a right out and the signs to the right off hurricane shoals.
    TX2Day and Rideandrepair Thank this.
