Air dryer keeps purging
Discussion in 'Freightliner Forum' started by dipmode, Dec 7, 2024.
  1. dipmode
    dipmode Bobtail Member
    4
    This is a 2022 Cascadia 126, the purge valve on the air dryer keeps purging every second. Asked a friend about this and he mentioned it could be the air dryer filter which I changed and that didn't fix the issue. I made a video which I will attach to this post.
    What would be the problem?
    Thanks
  3. dipmode
    4
    Changed the air dryer filter and that didn't fix the issue. What could be the problem?
    This is a 2022 cascadia 126
  4. Inderjit
    Inderjit Heavy Load Member
    788
    745
    Sep 17, 2017
    The air from the governor that unloads the compressor and opens the purge valve on the dryer is leaking off somewhere.
  5. dipmode
    4
    Thank you veere, I just put it in shop and let's see what they say. I asked my one mechanic and that's what he had told me as well.
  6. supersnackbar
    20,824
    56,536
    Aug 19, 2007
    Your Town, USA
    It is definitely the air governor. They use to be an easy fix without crawling under the truck, but they moved it on most of today's trucks so you have to crawl under.
  7. DeeDubb
    DeeDubb Bobtail Member
    5
    Aug 3, 2025
    My truck kind of had a ticking after the air dryer would purge for awhile then it would go away. I replaced the governor and unloader valve on top of the compressor, don’t know which one fixed it but it did fix it.
  8. cascadia4life
    cascadia4life Light Load Member
    107
    99
    Apr 21, 2023
    My 2016 ghg17 has the same tick. Always did. Had both of those replaced.
