Air manifold leak in same spot as before
Discussion in 'Volvo Forum' started by ashtre, Feb 7, 2023.
  1. ashtre
    ashtre Light Load Member
    109
    108
    May 9, 2016
    Replaced this manifold above driver fuel tank and it's already leaking from same spot, possible that I got a bad brake chamber or something pushing air back? I hold air about 6 mins riding down interstate but when parked I can hear air escaping out top right corner of this thing.
  3. loudtom
    loudtom Road Train Member
    1,717
    2,806
    Aug 26, 2016
    I'd try cutting the end off the tubing and reinstalling it. It might be the tubing, not the manifold. Make sure it's straight and not pushing or pulling the fitting too hard.
  4. ashtre
    109
    108
    May 9, 2016
    Thanks will try that
    blairandgretchen Thanks this.
  5. blairandgretchen
    13,958
    76,757
    Dec 9, 2011
    South west Missouri
    Get you a little plastic tube cutter tool - they make a nice neat 90 degree cut VS. using snips or a utility blade, no matter how accurate you think you are.
