amount of pull needed for a 5th wheel handle
Discussion in 'Experienced Truckers' Advice' started by buddyd157, Apr 10, 2019.
  1. buddyd157
    buddyd157 Road Train Member
    13,582
    34,899
    May 25, 2017
    under a shade tree
    ok, like the subject line states...
    does anyone have an idea on the approximate pulling poundage (force) a driver faces, when he is pulling the 5th wheel locking handle??
    is it 10 pounds, 20 pounds, 30, ..??
    i been trying to explain to someone it takes a certain amount of "pull" to unlock, but unless i can say near the exact amount, he won't get the idea.
    thanks to all in advance
  3. Cam Roberts
    Cam Roberts Road Train Member
    1,621
    1,938
    May 13, 2018
    Lepton1 Thanks this.
  4. buddyd157
    13,582
    34,899
    May 25, 2017
    under a shade tree
    and i would believe that's what it takes, in all my years, i only knew some that were easier than others to pull, even with a pulling tool.
    i would "figure" that someone who works out with weights, would have a somewhat close idea?
    Cam Roberts Thanks this.
  5. gokiddogo
    gokiddogo Road Train Member
    8,786
    14,769
    Mar 5, 2012
    Ontario Canada
    Seems to vary. Even with my well maintained, new equipment. Usually it's very easy. Sometimes needs a very good pull. I am not in good shape at all and I can always manage. The key is the J bar. If I had to do it by hand it has proven impossible before (on previous equipment, as company guy). Proper tool for job is the key.
    Lepton1 and buddyd157 Thank this.
  6. 25(2)+2
    18,759
    45,986
    Sep 18, 2006
    the road less travelled
    Depends on how well it works, our newer trucks are much easier than the older ones where you also usually have to lift and pull. If 10 to 20 doesn't do it, you may need to back up slightly to take off the tension holding the jaw shut.
  7. buddyd157
    13,582
    34,899
    May 25, 2017
    under a shade tree
    right, on my now former truck, it was an easy pull, but i still used the tool.
    but some, dear god...you needed a Sherman tank for help.
    so i'll tell this guy about 15 pounds worth of pull, as a general idea.
    25(2)+2 Thanks this.
  8. Lepton1
    Lepton1 Road Train Member
    12,647
    25,589
    Nov 23, 2012
    Yukon, OK
    It also depends on the type of 5th wheel: Jost, Fontaine, etc. There are 5th wheels that require a minimum 20 hours a week in Gold's Gym, then others can be pulled by a three year old.
  9. Moosetek13
    Moosetek13 Road Train Member
    14,984
    19,034
    Nov 1, 2010
    Burnsville, MN
    And it also depends on the temperature.
    The colder it is, the more effort needed to get it out because the grease is very stiff.
    And when it is very cold you will have to keep it pulled out for several seconds to let things slide into place.
    25(2)+2, Lepton1 and booley Thank this.
  10. Cam Roberts
    1,621
    1,938
    May 13, 2018
    Yeah but it’s an interesting topic you bring up though. Even though, 2 different 5th wheels will yield different results. Some trucker on here must have a scale. It would be interesting to see what the results would bring nonetheless.
  11. Farmerbob1
    Farmerbob1 Road Train Member
    3,685
    5,792
    Jan 17, 2017
    I would say that on an undamaged fifth wheel, the minimum force needed to unlock a fifth wheel is about 30 pounds.
    That is if it is perfectly aligned and well lubricated. The upper limit goes into the hundreds of pounds, to the point where you have to adjust the truck itself before you can release the fifth wheel.
    I have two fifth wheel pullers. One is a short, light puller that I always try to use first. The second is about 2 feet longer and has a much more solid handle. I am a 270 lb man with good upper body strength. Every now and then I cannot get enough leverage to release a 5th wheel lever with a 4 foot puller and all my body weight, even if I jerk at it.
    Final Drive and Lepton1 Thank this.
