Another APU question
Discussion in 'Trucking Electronics, Gadgets and Software Forum' started by WREN, Oct 7, 2019.
  1. WREN
    WREN Medium Load Member
    378
    239
    Jul 17, 2017
    Florida panhandle
    Yesterday I was cleaning the truck and packing it. The APU was running and cooling the truck but I didnt have any sleeper power. It does have the inverter and the 2 110 plugs, but none of the sleeper lights or anything like that was working. Does the APU only power the 110 plugs and the ac/heater? If so, do I need to just leave my key in the on position to have power to the rest of the truck?
    Never had an apu so its all new and the videos/literature really doesnt explain this very well.
  3. mitrucker
    mitrucker Road Train Member
    5,488
    10,317
    Dec 15, 2010
    Lapeer, MI
    If you were just issued the truck, I would suggest asking the shop about it. If that’s not an option, drive it. Get a good full charge on the batteries, then recheck.
  4. WREN
    378
    239
    Jul 17, 2017
    Florida panhandle
    Its my personal truck that I just purchased a couple of days ago. Im not use to all this fancy new stuff or an APU so its all throwing me off lol. The batteries showed 13.3 volts since the APU does charge them.
  5. supersnackbar
    20,122
    52,803
    Aug 19, 2007
    Your Town, USA
    My Mack was tripping the low volt breaker under the bunk every time I started it last week. It shut down most of the sleeper lights and all of the 12v outlets, but my APU would start, run and charge the batteries. There is probably a fuse or a bad relay. They replaced the breaker and mine hasn't had an issue since. If it's a normal APU like a Thermo King tripac or Carrier, it shouldn't be connected to anything but the inverter and the batteries, and a wire to the ignition so it knows to shut down when you start your truck.
    WREN Thanks this.
  6. underdogg25
    underdogg25 Bobtail Member
    7
    4
    Jul 23, 2015
    I've been running my own truck with an APU now for the last 8 years. Done all the repairs myself when the warranty ran out. The APU is a completely separate unit from the tractor, except for the truck engines coolant, also fuel from the trucks fuel tanks which runs through both the APU and to Truck engine. Without the coolant and fuel from from the truck engine it will shut down the APU within a few minutes. The APU should charge the truck batteries, provide power to the Inverter, also has it's own ac unit completely separate from the trucks ac. Also if a bunk heater was installed with the APU it is also separate from the trucks heater. When the batteries on the truck get too loe to start. Just fire up the APU & presto the batteries with charge right up. Yeah! Saved me countless numbers of times. It's a beautiful thing.
  7. WREN
    378
    239
    Jul 17, 2017
    Florida panhandle
    @underdogg25 so how do I get the interior lights to have power if I'm running just the apu? Turn the ignition key to on?
  8. WREN
    378
    239
    Jul 17, 2017
    Florida panhandle
    Nevermind, got it figured out. Gfi was tripped
  9. jland1962
    jland1962 Bobtail Member
    34
    38
    Aug 15, 2018
    Hi. I don't have a reply to your comment other than to say, Good job! But you seem knowledgeable, so I'm asking for advice. I have a Thermo King Tripac APU. The inverter stopped working, off & on. The APU quits, on occasion. I jiggled the wires under the APU, and it started back, but for 3 hours or so. Not sure if it is bad wiring, bad inverter, APU issue...
    Suggestions?? TIA
