Any Secrets for Changing Coolant?
Discussion in 'Ask An Owner Operator' started by Oil Slick, Dec 24, 2017.
  1. Oil Slick
    Oil Slick Bobtail Member
    23
    8
    Aug 13, 2017
    My new/used 2015 T660 with ISX coolant looks pretty dirty at 340,000 mi. Are there any tricks to changing it other than drain and refill?
    I’m assuming it takes red coolant?
    Thank You and Merry Christmas
  3. HalpinUout
    HalpinUout Road Train Member
    7,074
    18,165
    Oct 2, 2011
    I don't know about the changing portion of your question but my 14 ISX takes orange coolant so double check to make sure its red. Merry Christmas to you also.
    bzinger Thanks this.
  4. xsetra
    xsetra Road Train Member
    5,199
    7,151
    Aug 21, 2011
    10speed4me Thanks this.
  5. bzinger
    bzinger Road Train Member
    16,659
    66,217
    Dec 10, 2014
    omaha , ne
    Lol..hit deer in Wisconsin last July insurance company changed it .
    Grubby and 10speed4me Thank this.
  6. shogun
    shogun Road Train Member
    6,075
    72,164
    Jan 23, 2009
    Doing a regen
    I have never done it on a big truck. But I would assume it would be the same as a car engine. Drain it, then refill it with clean water and some radiator flush, then run it for about 20 minutes with the heat wide open. Drain it out, then stick a water hose at full blast in the tank, open the bottom plug or disconnect the bottom hose and let it run with heat wide open again for another 15 minutes or so. Change out the thermostat, replenish with 50/50 and burp the air out, and change the coolant filter while you are at it if applicable.
    Grubby and rolls canardly Thank this.
  7. Diesel Dave
    9,770
    33,682
    Jan 20, 2010
    Hesperia, Ca.
    When you drain it, disconnect/drained from the bottom hose. Let it gush out.
    rolls canardly Thanks this.
  8. Snailexpress
    2,675
    6,069
    Apr 28, 2014
    Rocky
    If you have coolant dirty at this mileage you have bigger problem.
    Dirty coolant could be from
    1. Exhaust gases contamination - leaking head gasket/ cracks in head or engine block or EGR cooler
    2. Oil in coolant contamination - leaking oil cooler.
    3 Fuel in coolant contamination - Leaking fuel/water separator.
    NADA or some other stores have coolant test kits to check what is in coolant.
    Cooling system pressure test overnight will tell you where is leaks.
    And yes, Cummins ISX has coolant filter and coolant is red ELC.
    d281833, Justrucking2 and Oldironfan Thank this.
  9. shogun
    6,075
    72,164
    Jan 23, 2009
    Doing a regen
    Very true. Didn’t notice it being a new truck with low miles, OP, listen to Snail Express.
  10. mitmaks
    mitmaks Road Train Member
    2,592
    2,113
    May 16, 2014
    Factory fill is Delo ELC coolant.
  11. Oil Slick
    23
    8
    Aug 13, 2017
    Thanks for the info. My first step is to change it but would like to get a sample analyzed.
    How many gallons does the system hold?
