APU thermo king startup scortching hot.
Discussion in 'Questions From New Drivers' started by dboot01, Nov 13, 2023.
  1. dboot01
    dboot01 Light Load Member
    135
    225
    Nov 8, 2021
    Just got in a truck with an apu for the first time. Why when I put the heat on it comes on lava hot for 5 minutes then turns off again? Is this a censor thing or what? I know the batteries are fine. I have to keep turning it off and on again to get it going
  3. tscottme
    tscottme Road Train Member
    Is the heat being produced by a seperate system or are you just twisting the temp knob from cold to hot. In every APU I had the heat came from a seperate fuel heater and the A/C came from the APU's air conditioning system. If the heat comes from a fuel heater (Webasto?) you have a fault in the fuel heater. In every APU system I had the heat produced by turning the temperture knob to hot was barely room temperature, at best. I think I have only ever had Thermoking APUs. I never had battery-based, Carrier APU, or other gadgets.
  4. Judge
    92,352
    if it hasn’t been used in long time, may have to keep it going a bit, fuel in heater may be old.
    try it a few times to get good fuel to it.
    dboot01 and tscottme Thank this.
