Auto 5th wheel jaw release help
Discussion in 'International Forum' started by earnies2, Mar 16, 2021.
  1. earnies2
    earnies2 Medium Load Member
    691
    281
    May 17, 2012
    Dedham, MA.
    I have a 2009 prostar with the incab 5th wheel release... I'm having issues that I can't figure out. The truck has not been used for 9 month's due to a motorcycle accident and then covid....I had the double fitting valve changed before the accident and haven't used it till now. That being said when I apply my parking brakes it unlocks the 5th wheel with air pressure....when I release my breaks the pressure goes away.... the electric switch sounds like its working but I'm stumped...
  3. BoxCarKidd
    BoxCarKidd Road Train Member
    4,548
    6,641
    Aug 26, 2014
    Release is surely just for the slide?
    Is the double fitting valve the the parking brake push pull valve assy? If so I would assume a line was crossed up in the dash.
    earnies2 Thanks this.
  4. earnies2
    691
    281
    May 17, 2012
    Dedham, MA.
    Release is for the 5th wheel jaws to release the trailer.
  5. BoxCarKidd
    4,548
    6,641
    Aug 26, 2014
    Never saw one of those on a road tractor just spotter trucks. Sounds like a bad idea.
  6. ChuckMartel
    ChuckMartel Light Load Member
    160
    94
    Jan 22, 2021
    Same.
    Was it factory installed?
  7. earnies2
    691
    281
    May 17, 2012
    Dedham, MA.
    Yes factory installed all Werner some US express and England trucks have them. Its a nice option especially on a rainy, snowing or when you are in the mud. You still need to get out and remove your air lines and electrical cable but you don't need to pull your 5th wheel. You can only release it when the tractor brakes are applied so its safe.
    mjd4277 Thanks this.
  8. Arctic_fox
    4,509
    25,470
    Sep 16, 2016
    That 5th wheel release is actully getting to be pretty common. I know one company i worked for was installimg them on all new trucks as a standard option. Their great to avoid getting dirty reachimg under the trailer. And their great when they work.
    That said, try greaseing your jaws and ourgeing your airlines. Could be they are stiff with old grease that has been sitting almost a year. Otherwise no idea.
    D.Tibbitt and earnies2 Thank this.
  9. flood
    flood Road Train Member
    4,168
    4,047
    Dec 25, 2010
    why do you think it's a bad idea.....?
    I've had 10 trucks (2000-2015) with it.... love it
    BoxCarKidd Thanks this.
  10. earnies2
    691
    281
    May 17, 2012
    Dedham, MA.
    Its not the 5th wheel its somthing in the operation with the air pressure it shoulnt supply air without touching the switch.
    flood Thanks this.
  11. supersnackbar
    20,099
    52,621
    Aug 19, 2007
    Your Town, USA
    I had it on the '95 FLD I owned...and all of the company trucks where I work have it.
    D.Tibbitt and BoxCarKidd Thank this.
