Axle weights and permits on over length I beams
Discussion in 'Flatbed Trucking Forum' started by W Bench Farms, Mar 22, 2022.
  1. W Bench Farms
    W Bench Farms Light Load Member
    211
    351
    Oct 16, 2017
    Have a load of 60' beams to haul. 48' spread with solid bulkhead on the trailer, so will have about 15' of overhang on the back. 48000 load, I'm about 31000 empty, so won't be over gross. I'm thinking this will be a divisible load, so have to keep trailer axle weights under 20k. I'm a little concerned about being over on the axles. Over length permits not an issue. How do you guys do it, or can you even make it work?
  3. Jacoooooooo
    Jacoooooooo Heavy Load Member
    748
    1,054
    Oct 20, 2013
    You may end up between 38-42k on the spread by my estimate.
    CAXPT Thanks this.
  4. Judge
    94,231
    Man..
    That bulkhead is going to be a major issue.
    I always scooted 5 ft forward(all I could do without being in headache rack) as my airlines were run under the rack.
    Then You only have 7’ stuck over the rear.
    Your going be over axle
    CAXPT Thanks this.
  5. W Bench Farms
    211
    351
    Oct 16, 2017
    Exactly what I was thinking.
    Am I correct in thinking that since it's beams that it's divisible and can't permit the over axle?
    CAXPT Thanks this.
  6. cke
    cke Road Train Member
    6,358
    78,332
    Aug 4, 2013
    Colfax Wi
    You are correct
    CAXPT Thanks this.
  7. cke
    6,358
    78,332
    Aug 4, 2013
    Colfax Wi
    I’d bet a lot of money that you’ll be well over 45,000 on the spread.
    baha, kylefitzy, beastr123 and 2 others Thank this.
  8. W923
    W923 Road Train Member
    1,452
    4,528
    Feb 28, 2022
    I am with cke. Your going to be 42+ on your spread
    And you won’t be able to get a permit because it’s divisible
    Only way you’re going to make it work is to loose the bulkhead
    CAXPT, Phoenix Heavy Haul and cke Thank this.
  9. cke
    6,358
    78,332
    Aug 4, 2013
    Colfax Wi
    If the load is 48,000 you’re going have to get a minimum 4 feet out front.
    CAXPT, W923 and Ruthless Thank this.
  10. roundhouse
    roundhouse Road Train Member
    3,213
    7,339
    Jul 11, 2018
    How much overhang can you have before you need a pilot car ?
    how many different states are
    You traveling through ?
    cke and W923 Thank this.
  11. CAXPT
    CAXPT Road Train Member
    3,488
    16,622
    Feb 10, 2008
    That's decided by the states you run through. Some are only 3 ft. Others 5 ft. You have to know exactly what you're over, and if permittable, again, because it's divisible. Also, whether they allow front overhangs and what lengths, and there maybe limits on both front and back.
    cke Thanks this.
