Bad batteries?
Discussion in 'International Forum' started by Airman89, Apr 8, 2016.
  1. Airman89
    Airman89 Light Load Member
    148
    15
    Jul 8, 2015
    Ive been thinking I had a ground issue causing my lights to go out but now I'm leaning towards bad batteries, but they're only maybe 6 months old? I turned the lights on and off 3 times for maybe 20 seconds each time while I was cleaning grounds and rechecking the lights and now the truck won't start. Voltage at batteries is 12.6v.
    I've noticed the voltmeter gauge drop from 13.8v to around 12.8v while running when I simply turn on the heat, then drop another volt when I hit the lights.
    Are these batteries already bad? Not holding a charge?
    Thank you,
    Adam
  3. Jonkie
    Jonkie Medium Load Member
    651
    395
    Mar 29, 2016
  4. xsetra
    xsetra Road Train Member
    5,196
    7,147
    Aug 21, 2011
    2nd vote for alternator. Or loose belt. Most likely Alternator not charging.
    Also check the fluid level in your batteries.
    I just tested my batteries and 3 of 4 tested weak. Check acid level and it was low. Charging was OK and now all the batteries are holding charge as well.
    Airman89 Thanks this.
  5. ExOTR
    ExOTR Windshield Chipper Extraordinaire
    1,706
    1,893
    Jan 23, 2013
    Fort Worth, Tx
    Regulator? Yank off the alternator and take it in to a shop, let them spin it and see how many amps it's pushing out.
  6. Airman89
    148
    15
    Jul 8, 2015
    So even if the alternator is pushing out over 14v it may still be bad because it isn't pushing out enough amperage?
    I just don't understand how the batteries were drained so quick by turn the light on and off a few times. So everyone is leaning toward a bad alternator?
  7. BoxCarKidd
    BoxCarKidd Road Train Member
    4,548
    6,641
    Aug 26, 2014
    Answer to question # 1 is yes.
  8. RustyBolt
    RustyBolt Road Train Member
    2,073
    3,335
    Feb 21, 2015
    Bement, IL
    Worked for a company several years ago and my truck was having issues after being serviced by said company. Alternator got replaced. Same issue. Batteries got replaced. Same issue. Alternator cable replaced. Same issue. Then a greenhorn mechanic with less than six months experience noticed that the batteries were hooked up wrong. Problem solved. Point is...... Check everything. Again.
  9. blairandgretchen
    13,933
    76,584
    Dec 9, 2011
    South west Missouri
    May trouble shoot better if you can test output while another buddy turns on lights/ heater fan/ups RPM - I'd guess slipping belt under load.
    If you do buy batteries get the 740 CCA, not 1000 CCA - less plates, less chance of corrosion , last longer. Buy from Freightliner - brand that is warrantied by any TA/Petro.
    Load test batteries.
  10. xsetra
    5,196
    7,147
    Aug 21, 2011
    To check if your alternator is working, after you get truck started, disconnect the negative posts. Truck should keep running. If you disconnect positive posts the motor will die if equipped with those small power leads to ECM. Well, that's what happened to mine.
    I had the 750 CCA batteries. They lasted me 1.5 years. I bought those last time because that's what was available.
    I had 1100 and now I have 950.
    The battery store owner explained the batteries all have the same number of plates. The difference is the thickness to the plates and the purity of the lead. He explained batteries from many moons ago. Were the same size but only rated for 550CCA. This allowed for more acid which also acts as a coolant during the charge/discharge cycle.
    When you solve your problem, let us know. Thanks. Good luck.
  11. JAYRODPA
    JAYRODPA Light Load Member
    157
    109
    Dingmans Ferry pa
    get a cheap load tester. one with heating coils. batteries could all read 12v but you may have one that drops off under load. if not I would check all the cables. check the ground connected at the frame. most of the time that's where it would be. disconnect it and clean the connector and the frame. check the cables going to the starter and wires going to the alternator. look for cable swelling. that's a sign the cable got to hot. if all looks good take the alternator and have if tested. make sure all your battery's are all the same CCA. one battery higher or lower can damage the rest.
    brian991219 and Airman89 Thank this.
