Bad grinding promblems when down shifting from high to low
Discussion in 'International Forum' started by Tyler Jennum, Jun 12, 2015.
  1. Tyler Jennum
    Tyler Jennum Bobtail Member
    I'm new to trucker but I do know how to down shift. I drive a 07 international and when I'm down shifting from 6-5 (high to low) it makes a loud grinding noise for about 2-3 seconds when I hit the flipper down. It doesn't do it all the time but it has been doing it more and more. Any tips would be awesome
  3. BoxCarKidd
    BoxCarKidd Road Train Member
    4,548
    6,641
    Aug 26, 2014
    Search PedigreeBullDog"s post on this subject. I thank everyone else explained what the problems may be and he explained how to drive it.
    Tyler Jennum Thanks this.
  4. supersnackbar
    20,097
    52,607
    Aug 19, 2007
    Your Town, USA
    Either you aren't pre-selecting your range shift (flipping the switch) before moving your stick or your transmission is worn. Generally if your splitter is grinding from high to low, your range syncro's are worn out (or going bad since it does it intermittently, I am betting it does is more when you are braking harder than usual) The only syncro's in a big truck trans are in the range box and are usually worn out if the previous driver didn't flip the switch before moving the shifter on a regular basis.
    Eaton/Fuller had one of those info-posters you see in repair shops years ago about the very same problem. They were seeing a lot of bad wear in the range boxes of 9 and straight 10 speed transmissions and were refusing warranty on gearboxes they could prove weren't shifted as directed.
    SLANT6 and Tyler Jennum Thank this.
  5. poppapump1332
    poppapump1332 Road Train Member
    2,986
    2,464
    Jan 2, 2010
    birdsboro,pa
    Syncos are bad in back of tranny
  6. 77fib77
    77fib77 Road Train Member
    11,646
    76,795
    Jul 7, 2010
    St Louis
