Basic truck care
Discussion in 'Questions From New Drivers' started by asphaltreptile311, Nov 23, 2016.
  1. asphaltreptile311
    asphaltreptile311 Road Train Member
    1,480
    2,847
    Jun 16, 2016
    today in class the instructor told us to let the truck idle after a long run to let the turbo cool down. Any tips on just basic maintenance like draining air tanks at the end of the day, things of that nature?
  3. thejackal
    thejackal Road Train Member
    1,359
    1,456
    Mar 1, 2014
    detroit mi
    Wow..u have an old school instructor. Good. Keep your ears open and ask him lots 'o questions.
    Basic maintenance begins with preventivery maintenance. Tire pressures oil levels easy on the tranny stuff like that. Also when u do a pm, don't skimp. Even check the air dryer cartridge.
    Smooth sailin.
    Bfr38 and Lepton1 Thank this.
  4. MACK E-6
    50,173
    239,826
    The turbo thing is actually more of "don't shut it down immediately after a long climb".
    No need to completely drain your air tanks. Just don't leave water in them. If you crack the valves and only air comes out, you're good.
    JReding, ChaoSS, wore out and 2 others Thank this.
  5. Moose1958
    Moose1958 Road Train Member
    15,299
    33,972
    Dec 17, 2010
    Williesburg, Virignia
    A large part of the US fleet you can't idle for long before the engine idle cutoff stops the engine anyway.
  6. MACK E-6
    50,173
    239,826
    Well, after a hard pull a couple of minutes should be enough to cool the turbo.
    wore out Thanks this.
  7. STexan
    STexan Road Train Member
    14,963
    29,160
    Oct 3, 2011
    Longview, TX
    If you get a newer truck that is properly maintained, and you don't beat it up, there will be very little for you to worry about other then making sure everything looks good. However, if you get an older truck, a lemon, or a truck that has not been well maintained or well operated ... well, good luck and you can't be too careful.
    Modern engines are almost bullet proof and idiot proof. You will hear stories about the DPF (exhaust treatment) components failing, but most of the bugs have been worked out lately, and as long as they are properly maintained with proper replacement parts, they just aren't a problem anymore, either. You'll know in the first 2 months what kind of truck you were issued and if it's going to make you money or make you sit a lot. (and it's a crap shoot at many large and small carriers)
  8. street beater
    street beater Road Train Member
    4,578
    20,669
    Apr 18, 2014
    cold as hell, MN
    Just set the cruise control. Overrides (most) auto kills
    JReding Thanks this.
  9. ChaoSS
    ChaoSS Road Train Member
    3,338
    6,758
    Sep 20, 2014
    When you get your truck, read the manual. Familiarize yourself with the warning gauges so you don't end up seeing one and not having any idea what it means or if you need to worry about it right now. (Or ever.)
    The manual should give you a run down on what to do with it. Warm up, cool down, draining tanks. On a def truck with battery kill switch don't shut that off until the pumps have cycled the def out of the lines, etc.
  10. CargoWahgo
    CargoWahgo Road Train Member
    3,912
    3,945
    Jan 10, 2012
    Louisville, Kentucky
    Turbo will actually be good just sitting at a stop sign then pulling into the stop & parking. That's more for a rest area scenario.
    Somin to think about before you jump out 100 mph to pee.
    Buy a big sack of bulbs for your truck so you don't have to call your road service....don't be THAT guy xD.
    Ask them to show you where the turn signals get pulled out so you know where to stick said bulb into plug.
    ....we've all been there stealing a brake light from another company(the same) trailer in Nogales Pharr or whatnot... Keep a stock of bulbs.
  11. JReding
    JReding Road Train Member
    1,957
    3,511
    Sep 8, 2014
    Puyallup, WA
    I would be curious how many fleets have left that function in, and how many (like FedEx Freight) have overridden even that function? They started doing that back when I was still there as a fuel saving measure.
