Benson stepdeck hub sight glass
Discussion in 'Flatbed Trucking Forum' started by mitmaks, Apr 12, 2025.
  1. mitmaks
    mitmaks Road Train Member
    2,586
    2,102
    May 16, 2014
    I don't see how you check fluid on these with solid cover on the hub? How go you check fluid level?
  3. Big Road Skateboard
    7,095
    40,236
    May 2, 2021
    It's grease, or a semi fluid synthetic grease, not oil.
    It does not need to be regulary inspected. Check for leaking wheel seals , and run.
    cke and CAXPT Thank this.
  4. mitmaks
    2,586
    2,102
    May 16, 2014
    So how do you check it and when are you supposed to replace it?
    beastr123 Thanks this.
  5. Big Road Skateboard
    7,095
    40,236
    May 2, 2021
    If you don't have a wheel seal or hub cap leaking, you're GTG.
    I jack mine up every 3-4 months and check bearing play. The older my trailer gets, I'll do that more frequently
    beastr123, cke, CAXPT and 1 other person Thank this.
  6. Big Road Skateboard
    7,095
    40,236
    May 2, 2021
    For specific guidelines, i'm sure Hendricksons website has specific maintenance guidelines
    beastr123, cke and CAXPT Thank this.
