Block Heater How does it work?
Discussion in 'Ask An Owner Operator' started by Siinman, Sep 17, 2022.
  1. Siinman
    Siinman Road Train Member
    5,523
    14,209
    Mar 5, 2017
    Kansas City, MO.
    I have never needed to use them since I always had a APU that was plumbed into the engine. I noticed it has a different kind of plug that turns sideways on one if I remember correctly. Can I plug that into the truck bunk area with an extension cord? If so why would they not just make a switch to kick it on instead of plugin?
  3. blairandgretchen
    13,958
    76,753
    Dec 9, 2011
    South west Missouri
  4. AModelCat
    164,899
    If you're trying to power it with the inverter your batteries might last 10 minutes if you're lucky.
    One sideways prong on a household style outlet indicates a 20 amp circuit.
  5. Siinman
    5,523
    14,209
    Mar 5, 2017
    Kansas City, MO.
    So if I need it on the road I could buy a little 2000 W or higher generator? How long does it take to warm up oil?
  6. 062
    062 Road Train Member
    6,333
    33,973
    Oct 20, 2013
    They generally heat the coolant. They make heating elements for the oil, but it would be part of a arctic package.
    How long it takes depends on outside temp,how long truck has been off etc.
  7. blairandgretchen
    13,958
    76,753
    Dec 9, 2011
    South west Missouri
    Mine goes into the coolant manifold behind the water pump. A 2000w generator might do it - there’s no start up capacitor draw like a microwave.
    In winter below 30 degrees, mine will warm the block to 75 degrees after about 3 hours I guess.
    So it doesn’t heat the oil, just the coolant through the engine/radiator.
    They need to be immersed and will burn out quickly if you run the engine and it hits an air pocket. I leave mine off for a minute or two before start up.
    Check all your wiring carefully - don’t want to electrify your truck!
  8. AModelCat
    164,899
    Block heater won't heat oil, just coolant. Oil pan heater will warm the oil. Unless you're up in the northern parts of Canada you shouldn't have an issue with cold oil that couldn't be handled by just running winter weight oils.
  9. Keepforgettingmypassword
    Keepforgettingmypassword Heavy Load Member
    738
    938
    Jan 11, 2022
    What is your goal. Diesel fuel freezes and becomes gel. The block heater keeps the block warm to prevent a slow or no start condition.From what I'm told it also keeps the oil from thicking thru the night.
    The plug you mentioned above is to plug in the heater to the block while the engine is off.
    Plugging the block heater to the invertor or pay will the battieres on the truck because of all the jucie it needs to be powered.
    Depending on tempature and location in the country and amount of time the engine will be off. You may not need a block warmer plugged in. Some states and temptures you will be ok with antigel in the ranks. This is all I know about block heaters. I have never used mine.
    Edit. If most plugs are close to the same. My grandad popped out one of his freeze plugs and it mounted in that whole some how.
  10. Keepforgettingmypassword
    738
    938
    Jan 11, 2022
  11. Siinman
    5,523
    14,209
    Mar 5, 2017
    Kansas City, MO.
    Ok Thanks for clarifying that. I never have messed with them so just making sure I get how they work before ever trying it out in winter. I doubt I would ever really need to use it since I live in MO. I just wanted to know incase I had to use it at sometime.
