Breaking loose screws
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by Gentlemanfarmer, Nov 5, 2020.
  1. Gentlemanfarmer
    Gentlemanfarmer Medium Load Member
    365
    384
    Feb 26, 2010
    Greenville, FL
    I am repairing my wood boards on my flatbed trailer. The screws hold the wood to the trailer are hex head screws that use a T40 bit, but these screws are in so tight that neither my Ryobi impact wrench (1/4 inch drive) or electric drill will budge them. I have sprayed with a penetrating lube, but still a no go. What tool would you recommend to back these screws out?
    jamespmack Thanks this.
  3. sirhwy
    sirhwy Medium Load Member
    347
    709
    Sep 1, 2011
    Central Iowa
    How about a regular Allen wrench, with some sort of a piece of pipe slipped over it to use as a cheater bar? So basically, you would be extending the handle for more leverage.
    Gentlemanfarmer Thanks this.
  4. AModelCat
    164,668
    Probably going to break or strip before they move unfortunately.
    pushbroom, Goodysnap and tommymonza Thank this.
  5. tommymonza
    tommymonza Road Train Member
    4,519
    12,849
    Sep 10, 2013
    S.W. Florida
    You could try a hand impact. The kind that you hit with a big hammer.
    I have one that takes a 3/8 drive and has some weight behind it.
    The combination of hitting it jars the screw along with keeping the torcx bit seated in the screw.
  6. tommymonza
    4,519
    12,849
    Sep 10, 2013
    S.W. Florida
    If that doesn’t work buy some reverse drill bits.
    I spent 60 hours removing a irreplaceable rub rail on a 45 foot sailboat I restored .
    Half the 150 screw I had to remove stripped out but when I drilled them with the reverse drill bit they came out once they were half drilled.
    Chinatown and Gentlemanfarmer Thank this.
  7. Goodysnap
    Goodysnap Road Train Member
    3,772
    9,196
    Jul 12, 2017
    Pneumatic impact wrench 3/8 drive is heavy enough. Will need a good quality hardened bit. Removing old screws is ussually a lost cause. Cut the old wood between the crossmembers, cutoff the old screws and drill new holes for new screws in your new boards. Mark your old screw locations so you dont drill into an old screw. They will not drill.
  8. Klleetrucking
    Klleetrucking Medium Load Member
    378
    346
    Dec 11, 2010
    S.C.
    Are the deck screws into aluminum or steel?
    On my Reitnourer, I had good luck with a 1/2" steel rod held with vice grips. Three good whacks with a BFH on the head of the screw and all but eight I got out and was able to use the factory holes. Once the bond of the dissimilar metals was broken I could tease them out with little problem.
    tommymonza and Gentlemanfarmer Thank this.
  9. Chinatown
    Chinatown Road Train Member
    77,751
    184,484
    Aug 28, 2011
    Henderson, NV & Orient
  10. SmallPackage
    5,784
    18,571
    Dec 20, 2019
    Marion Texas
    Most of the time those screws are self tapping with a fine thread. Once they go in they will not come back out without twisting off.
    You will have to let them break, remove board, grind the screw stub level with the crossmember and use the same type screw new. Drill them in a 1/4 inch or so away from the original.
  11. jamespmack
    216,478
    Do not waste your time. Either torch the head off or push the board up with a port a power. Then torch flush and drive them down and out. Try to reDrill holes offset.
    Don't waste your time trying to remove old bolts.
    pushbroom, FLHT, AModelCat and 2 others Thank this.
