Buckling when turning
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by Mcast3092, Oct 5, 2022.
  1. Mcast3092
    Mcast3092 Light Load Member
    137
    107
    Jul 31, 2018
    Good morning everyone looking for a little advice on an issue I’m having. I drive a 97 Kenworth T 600, truck is an overall great shape but when I turn whether it be high or low speed the truck kind of makes a buckling sound and clunk underneath the cab. Anybody have any experience with this if so any help would be great. Thanks in advance.
  3. blairandgretchen
    14,018
    77,326
    Dec 9, 2011
    South west Missouri
    Pete 379 1995 did that before I changed out the spring hanger bushings in the front.
    It would quiet down after a good grease, then come back.
  4. Big Road Skateboard
    7,288
    41,509
    May 2, 2021
    Your springs are sliding side to side on tge spring pins. They're under pressure, so you get the loud pop.
    Shims should do the trick.
  5. kranky1
    kranky1 Road Train Member
    2,253
    8,855
    Sep 16, 2015
    Ontario, Canada
    Be worth looking at the cab isolators.
    Rideandrepair Thanks this.
  6. Mcast3092
    137
    107
    Jul 31, 2018
    Update: took truck into suspension shop. Gentleman here says it is very possibly the springs themselves. Says they are and old style composite springs that aren’t available anymore. Have to do conversion to newer springs. Estimate $2900
    Rideandrepair and MartinFromBC Thank this.
  7. Dino soar
    Dino soar Road Train Member
    4,819
    27,072
    Dec 8, 2017
    As You Wish but if those Springs sit level the Springs are not your problem, in my opinion. Not unless there's some other real reason like one of the leaves has actually broken or something like that.
    Someone needs to look over the front end on that truck as well but that is what the spring hangers do when they wear out. It is very common to have problems with the hangers especially if the truck does not get greased very much.
    When was the last time the truck was greased? What they need to do is let that front end hang and grease them. Grease the hell out of them and then see how it is for you. If it's better at all that's your problem. And your shocks probably need to be replaced because your shocks pretty much always need to be replaced. When they are replaced and working right they really help with dampening the shock.
    I also second checking the cab isolators. They can cause some creaking and moaning but a lot of times you'll feel the cab shake when you go down the road straight, if they are really worn out. It's very common that they can be deceiving you into thinking you may have a Driveline related problem or wheels tires Etc.
    Rideandrepair and Mcast3092 Thank this.
