Building a new truck
Discussion in 'Questions From New Drivers' started by Big Jim’s Hauling, Apr 17, 2021.
  1. Big Jim’s Hauling
    Big Jim’s Hauling Bobtail Member
    Apr 17, 2021
    Need some advice from seasoned professionals. Planning to buy a 2022 KW 900L w/86 studio sleeper. Will be running a 53’ step deck trailer with spread axle and fold over dovetail ramps (3). Truck will have 18 speed transmission. What should rear differential gear ratio be and what front end should I order? Understand float tires may be best, but educate me. Been running a Hotshot setup and moving up to a big truck under my own authority. Thanks in advance
    Lonesome Thanks this.
  3. Judge
    94,101
    I’d say at least 13200 steer axle rating,
    3.36 rears
    Do anything you want it too.
    Bridgestone R284s 16 ply is what I run, have had good service 295/75r22.5
    slow.rider Thanks this.
  4. Old Man
    Old Man Road Train Member
    4,597
    13,471
    Apr 3, 2009
    Oklahoma City, OK
    How far can you slide the step deck to get weight on the steers? Make sure step has a shallow king pin. I’d go 18 or 24 inches.
    Bean Jr. and slow.rider Thank this.
  5. Brandt
    Brandt Road Train Member
    4,672
    6,474
    Sep 17, 2012
    Spec it for MPGs, 18 speed probably over kill unless you really want one. You want to run a transmission in direct drive for better MPG. Then pick how fast you normally want to drive, say 65. Then pick the rear end to match that.
    bzinger Thanks this.
  6. Banker
    Banker Road Train Member
    4,710
    16,289
    Aug 19, 2012
    You probably want to visit Eaton fullers road speed calculator to see what rear end you should choose. Asking what rear end you should have is kind of like asking what is the best truck to buy. It is user specific or personal preference in many cases. On the site you can input the tire size you plan on using and the speed you will want to run and the site will help you figure your best ratio. I have a #14,600 front axle with 18 ply 295/60 R 22.5 steers
    (carhauler) 255/70 R 22.5’s on drives and trailer, 2:64 rear end and an 18 speed transmission. I like to run 65 much of the time in direct drive (16) as this is my most efficient gear with less parasitic loss than my overdrive. When I want to run faster I run in single overdrive (17). I seldom need to use 18. Some people who don’t understand this setup will tell you that it doesn’t work. It has worked great for my operation however it may not work for you. That is exactly where the Eaton Fuller Road Speed Calculator may help you. Years ago the saying was “gear fast and run slow”. That is kind of what I did.
  7. Old Man
    4,597
    13,471
    Apr 3, 2009
    Oklahoma City, OK
    The 18 has a higher torque rating, good for big power.
  8. Ridgeline
    22,817
    125,561
    Did you talk to the sales dweeb?
    they should be able to give you a list of trucks with different specs that works.
  9. abyliks
    abyliks Road Train Member
    4,229
    10,089
    May 2, 2010
    ludlow MA
    Floats are overkill for a road tractor up to the 100kish weight range, regular tall 22.5 or 24.5 rubber should be fine.
    depending on how fast you want to run, where you run and 22 or 24” rubber, a 3.36, 3.55, or 3.70 ratio should be about perfect
    singlescrewshaker Thanks this.
  10. HillbillyDeluxeTruck
    6,039
    31,041
    Mar 3, 2013
    San Antone
    I'd personally spec a truck with something like 3.25's or 3.08's with an 18 if I was going to run very little overweight loads. The 18 gives you plenty of gears and you don't always have to run in top gear.
    My current truck has 11r22.5's and 3.55's. It spins right around 1400rpm at 65, which is good but it'd sure be nice too have another half gear.
    AModelCat Thanks this.
  11. abyliks
    4,229
    10,089
    May 2, 2010
    ludlow MA
    you also have to take off from a stop, either forward or backing up to a piece of machinery at job site delivery’s in soft ground/mud, prematurely destroying a clutch or shooting the axles out of the diff will kiss that tenth of a mpg savings with tall gears good bye
    I have 11/22.5s and 3.55 with an 18 and my n14 sings right along at 60 in direst or 70 in the big hole perfectly
    baha Thanks this.
