C15 Turbo troubleshooting
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by A_far_cry_from_perfect, Sep 20, 2023.
  1. A_far_cry_from_perfect
    A_far_cry_from_perfect Bobtail Member
    Alberta, Canada
    Recently (3 days ago) replaced the top turbo on a c15 cat acert. Truck now has a constant whirling/squealing noise coming from turbo, to the point that I've had to park the truck because the noise is unbearable. At first sounded just like the whirring of the fins but has progressed to an almost screeching. Has anyone else had this issue? Will try to add video. Video I currently have is too large.
  3. AModelCat
    164,747
    Sounds like a leak.
    Last Call and Magoo1968 Thank this.
  4. blairandgretchen
    13,936
    76,626
    Dec 9, 2011
    South west Missouri
    Check CAC for boost leaks.
  5. Magoo1968
    Magoo1968 Road Train Member
    2,056
    5,478
    Mar 18, 2021
    St Malo mb
    High idle then spray soapy water on all joints or better yet smoke test it ..new turbo probably produces more boost than old turbo so leak got worse .. btw if old turbo came apart it may of damaged the second turbo .
    Bean Jr. Thanks this.
  6. bjytech
    bjytech Light Load Member
    246
    222
    Nov 9, 2013
    I've seen many times after someone had a turbo changed where the steel accordion tubing then cracks because it wasn't loosened on both ends and reset so that it sits "neutrally" to the new turbo. This will cause them to crack and the leak usually screeches pretty loudly.
    Magoo1968 and Oxbow Thank this.
