Cab to reefer distance
Discussion in 'Refrigerated Trucking Forum' started by The Nomad, Apr 15, 2020.
  1. The Nomad
    The Nomad Bobtail Member
    7
    The Road
    I’ve been trucking for a while (van, step, and occasionally a tanker) but just curious what is a good distance between cab and unit for clearance? I prefer my 5th wheel as far forward as possible. Thanks in advance.
  3. rachi
    rachi Road Train Member
    4,246
    5,231
    Feb 25, 2010
    SoCal
    With 5th wheel forward its roughly 4'
  4. MRMTRANS
    MRMTRANS Medium Load Member
    408
    441
    Apr 28, 2015
    I prefer to have enough distance for the doors to swing all the way (open). I have a fixed 1/5th wheel and had an old trailer with the kingpin 42' from the nose. I just upgraded my trailer and the kingpin is 36' from the nose. It's easier to spend some time working on the unit with the truck is still hooked to the trailer. If your 1/5th wheel slides easily,, then this isn't a concern, if you don't mind sliding it sometimes.. At minimum, just make sure the unit doesn't crumple the cab fairings when taking sharp turns.
  5. jason6541
    jason6541 Road Train Member
    2,425
    5,366
    Mar 5, 2012
    Omaha, NE
    Don’t forget the clearance when tractor starts up a steep incline and reefer unit smacks top of sleeper from being to close. Seen it done more than once. Also don’t forget that area is generally a low pressure area and the condenser needs adequate airflow. Most trucks have weed burner exhaust and that hot air gets trapped in that pocket and can make the reefer unit run harder than it needs too
    TallJoe, stwik and KB3MMX Thank this.
  6. Tb0n3
    Tb0n3 Road Train Member
    4,739
    9,658
    Oct 5, 2012
    Earth
    What's the kingpin setback on a reefer? 24"? You can do the math and see how far the trailer corners swing past the front of the trailer in a turn, then add a foot maybe for dip clearance. I'm thinking the typical reefer is designed to take up that swing space with the reefer unit completely.
    Doing the math it looks like 33" minimum from the front of the trailer, not including the reefer unit to make a full clearance. So if the reefer sticks out more than that just back the reefer a foot off the cab and you should be good, though I'm only guessing the kind of angle you get on a dip swing.
    Sorry, the 30" was for a 96" trailer. 33" for a 102".
    Reason for edit: Fixed measurements.
  7. abyliks
    abyliks Road Train Member
    4,141
    9,767
    May 2, 2010
    ludlow MA
    7-8’ is about right....
  8. x1Heavy
    x1Heavy Road Train Member
    34,016
    42,144
    Mar 5, 2016
    White County, Arkansas
    I keep the reefer's front plate just in a vertical line at the front edge of the drivers first axle tire. That gives enough room for a man between on the catwalk AND positions the 5th wheel just a little bit forward of the center of the pair of drive axles.
    As a rule I do not move the 5th wheel. I'll run through the bag of tricks first before I touch moving that 5th wheel.
  9. Cat sdp
    Cat sdp . .
    21,318
    76,328
    Apr 8, 2012
    Orion's Belt
    Just about right.....
    Kawinige01, broncrider, stwik and 7 others Thank this.
  10. The Nomad
    7
    The Road
    Feet or inches??? ‘ is feet, “ is inches.
  11. abyliks
    4,141
    9,767
    May 2, 2010
    ludlow MA
    feet
    Big_D409 Thanks this.
