California engine questions
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by shotgun8, Jun 14, 2017.
  1. shotgun8
    shotgun8 Bobtail Member
    46
    33
    Jun 7, 2017
    Eastern Shore of Maryland
    So general question......Can someone explain the requirements for California.
    Are you allowed to run a 2006 or earlier?
    APU is required or not?
    Which 2007 + motor is a good motor?
  3. Strange77
    Strange77 Light Load Member
    59
    36
    Oct 1, 2011
    Does the silence mean absolutely no one knows lol? I would have sworn it mean you just couldn't idle in CA if it didn't meet Clean Idle Air, but I also think I've heard you can't cross the state line unless you meet 2007 emissions.
  4. UsualSuspect
    UsualSuspect Road Train Member
    1,257
    1,979
    Aug 14, 2016
    Yo Mama's
  5. shotgun8
    46
    33
    Jun 7, 2017
    So for reefer,, why does 7 years matter? If it is 10 years old and still clean or 2 years old and blowing smoke, does an arbitrary date make sense? So if you are running a 75 Peterbilt Cabover, are you going to get pulled over?
  6. Sharky88
    Sharky88 Heavy Load Member
    715
    851
    Sep 25, 2013
    In California you must have a truck that has a dpf filter. It dose not matter the year of truck as long as the filter is in place. That being said putting a dpf filter on an older truck is asking for problems. The engine was not designed for it and the back pressure causes problems. The only other way to enter is by using the limited use clause which is only good for 1000 mi a year.
  7. Diesel Dave
    9,783
    33,811
    Jan 20, 2010
    Hesperia, Ca.
    Really ? Mine hasn't had absolutely no issues, but I have a CAT.
  8. Diesel Dave
    9,783
    33,811
    Jan 20, 2010
    Hesperia, Ca.
    To the OP, roll the dice, I haven't seen any enforcement for awhile, and to answer your question, I think it's 07 engine. I have 94 Pete and am running the aftermarket DPF.
  9. Sharky88
    715
    851
    Sep 25, 2013
    Diesel Dave Thanks this.
  10. Diesel Dave
    9,783
    33,811
    Jan 20, 2010
    Hesperia, Ca.
    Sharky88 Thanks this.
  11. Diesel Dave
    9,783
    33,811
    Jan 20, 2010
    Hesperia, Ca.
    Im pushing around 600hp with a tune and a turbo to match it. I put the tune in and turbo. Like building your own performance set up. Plus, I don't have a heavy foot, it's only used when necessary(it's fun to go up a hill and stay on the passing lane). I'm basically set up pretty much max out cause of CARB. I could get a lot more but a man has to know his limitations. :D
