Cargo that needs heat
Discussion in 'Refrigerated Trucking Forum' started by Hkellogg, Apr 21, 2014.
  1. Hkellogg
    Hkellogg Bobtail Member
    I have an interesting question.
    I need to keep loads above 60 degrees (special cosmetics) while going through very cold weather, sometimes below -20. I used to run for Anchor Foods before their demise and ran for them about 6 months. At times we would have to heat a return load such as Cambel's Soup to keep if from freezing. For the life of me I cannot remember how often I had to fill the tank on the reefer in really cold weather. Does it take more fuel to keep a load heated or cooled? I'm thinking cooled myself.
    Just trying to get an idea of how long a 50 gal tank can keep a load at 60 degrees at below freezing.
    Thank you in advance.
    Harry
  3. Steeleandsonfarms
    Steeleandsonfarms Light Load Member
    278
    125
    Sep 16, 2012
    Edgerton, OH
    Learned something new today. Reefers are a climate control device not just a chiller.
  4. Balakov100
    Balakov100 Road Train Member
    3,938
    2,641
    May 10, 2012
    Temple, TX
    Really don't know how to Answer that.
    Lots of Factors.
    How old is the trailer and Unit.
    If the Drain Holes are plugged, that would help some.
    Temp, don't know if they are all like that.
    The Carrier I have now goes up to 90.
    Previous Compay had some TK Units, they seemed to go up to 86.
  5. windsmith
    windsmith Road Train Member
    7,296
    6,032
    Sep 2, 2011
    NEPA
    Outside temperature has a lot to do with fuel consumption. As was mentioned before, door seals, insulation condition, drain holes all factor in.
  6. 8thnote
    8thnote Road Train Member
    1,980
    3,687
    Aug 12, 2013
    Chattanooga, TN
    Just top off the reefer everytime you get fuel for the truck and you'll be fine
  7. Sly Fox
    Sly Fox Road Train Member
    1,016
    695
    Oct 29, 2009
    Heating a trailer is MUCH more cost-effective than cooling. No compressor. it's just using the heat from the engine to provide warmth for the blower. You'll use a lot less fuel per hour than running a load that's cooling, even if it's just a few degrees below outside temperature.
    For a 'protect from freeze load', it's best to run cycle/start-stop. Unless it's a special commodity that needs a very narrow range. I've hauled liquid plastics in containers and usually they're 80F continuous.
  8. Hkellogg
    Thank you for the great answers. I'm trying to figure costs. The unit is 3 years old, in good shape and I'm just trying to figure fuel costs in the pricing.
    Thank you again in advance.
    Harry
  9. CondoCruiser
    CondoCruiser The Legend
    19,726
    18,734
    Apr 18, 2010
    Tennessee
    I would figure two days on a tank. I sat on bananas before all weekend (48 hours) in -30* on a tank. I ran it on 64* to maintain 60* pulp. I can't tell you the specifics of what I had left. I just remember I didn't have to refuel.
  10. Powder Joints
    8,032
    8,496
    Sep 25, 2007
    Rosamond, SoCal
    Check the gauge everything you fuel the tractor. Normally I Rupp the trailer every other day, but I still check it everyday.
  11. madman118
    madman118 Light Load Member
    244
    148
    Mar 13, 2012
    Sacramento, CA
    The colder it is outside the harder the unit works to maintain temp. The crappier the trailer the more heat it looses. Newer units are more efficient than older ones. Most of my protect from freeze loads are medical and they're usually 5 or less pallets,65-70F , tuck em down behind the barrier door. I can usually get a good 4 days on a full tank with that set up. Full trailer of produce or other food product about 2 days on the newer trailer with the Carrier, and about 30 or so hours with the older trailers with the TK's.
