Carrier 2500 unit locked in continuous run mode
Discussion in 'Refrigerated Trucking Forum' started by tibois, Nov 15, 2015.
  1. tibois
    tibois Bobtail Member
    25
    4
    Nov 1, 2012
    I just bought reefer trailer with a Carrier X2 2500 that's locked in continuous run mode. Although I am new to refrigerated loads, I know that not all loads require continuous mode. I want to know is there a way I can unlock it without going to the shop, and how to do it?
    Thanks
  3. Balakov100
    Balakov100 Road Train Member
    3,938
    2,641
    May 10, 2012
    Temple, TX
    Needs to be reprogrammed.
    Take it back to where you bought it, shouldn't be hard to reprogram.
    Maybe see if there are some intellisets set up.
    Guess you can get the Software and a Cable can't be that hard.
  4. GioGur
    GioGur Bobtail Member
    Same problem continuous mode locked I got it in Ohio now I am in Texas plz help Tnx!!!
  5. reeferwrencher
    reeferwrencher Medium Load Member
    598
    1,555
    Aug 4, 2018
    Open the roadside door,there should be a plug terminal.Unscrew the cap and put jumper wire from the a pin to the b pin.Turn on the unit,it will tell you to remove jumper.Now follow the instructions and you shpuld be able to change it. Good luck
    650cat425 Thanks this.
  6. Tornike
    Tornike Bobtail Member
    Hey buddy did you fix your reefer?
  7. Tornike
    I have the same problem I don’t know what to do it’s locked it start stop Can you help me please thanks
  8. Bigwhitekent
    Bigwhitekent Bobtail Member
    I have an old Prime trailer with a Carrier Advance 2500 X2. It was locked in continuous run and I could not unlock it. I went to a Carrier dealer and they showed me the work around. The tech went into the intel’s-sets and switched it to “fuel hog mode”. This is effectively the the factory default setting and it will allow you to toggle between continuous and stop-start modes.
    I hope this helps. I could not find anything on the web regarding this issue.
