Hi Ever1
First time on forum and looking Good, sory to start off with HELP PLZ.
Can anyone recommend a good reefer tech . I have a high pressure problem no o e can figure out
Thanks
Carrier dealer
Discussion in 'Refrigerated Trucking Forum' started by Y-L, Oct 3, 2013.
I am a carrier certified tech,what have you tryed so far to figure out the problem?
Hi thanks for the reply
when I took it in they said nothing is wrong when running in continuous hi pressure alarm comes on and unit shuts down, they checked all sensors and solonoids and said it was good, air filter is good belts are good. Also unit goes out of range and says ALARM RST, I had a TK before that used to get code 10 and I changed everything u can imagine (had to sell it was so bad)
Thanks -
Ok well if this only seems to happen in continuous run that tells me that it more than likely is due to the fact that the mode automatically goes into high speed.as a result the compressor pumps harder and the unit is not sheading heat like it is supposed to.the most commen cause of this is the condenser is dirty and needs to be power washed out.in any good reefer shop this is the first thing they would do to eleminate that as the problem.
bullhaulerswife and Y-L Thank this. -
Take the inside cover off and get any trash out of the evaporator intake and wash it out too. You'd be amazed at the amount of plastic and paper trash that get sucked in off the product you load.
ShortBusKid, GITRDUN45, Y-L and 1 other person Thank this. -
Thanks
Just left dealer and did what u guys suggested, will let u know how it went.
Thanks againLast edited: Oct 4, 2013
