Carrier Supra 760
Discussion in 'Refrigerated Trucking Forum' started by Master6786, Aug 13, 2020.
  1. Master6786
    Master6786 Bobtail Member
    Hi guys, I just got a 16ft reefer runs Carrier Supra 760. The unit runs fine but it took an hour to pre cool the box from 77 to 40 degrees. It is normal? The box is empty and not a sunny day. Thanks!
  3. reeferwrencher
    reeferwrencher Medium Load Member
    556
    1,474
    Aug 4, 2018
    Probably ok,check if the ball is floating in the sight glass on the receiver tank and check the evaporator fans make sure they are all turning
    If it's a roll up door check the seals around it.
    KB3MMX Thanks this.
