Carrier Unit won't get below 9 degrees. Need -5
Discussion in 'Refrigerated Trucking Forum' started by Everett, Aug 8, 2018.
  1. Everett
    Everett Crusty Shorts, What???
    2,095
    6,401
    Oct 20, 2009
    Hampton,Ia
    Does not want to go below 9 for a minus 5 load, i added 2 small cans of freon ,got to 0 and thats it at 98 outside.thanks in advance.
  3. reeferwrencher
    reeferwrencher Medium Load Member
    572
    1,491
    Aug 4, 2018
    Is the ball in the sight glass on the reciever tank floating? If not it still might be low on freon.Other things to check-is it running on high speed,is the head pressure on the system high,if so the condensor might need to be washed,is the outside of the trailer sweating-if so the trailer insulation itself is degraded or never rated for low freezer load.Other possibilites such as bad compressor heads or tx valve will likely require you to take it to a shop for repair.Hope you get it workin.
  4. Everett
    2,095
    6,401
    Oct 20, 2009
    Hampton,Ia
    ya it pretty sweaty inside and out im pretty sure the compressor is bad blew oil all over the back of tractor too so a seal went out somewere .there was no liguid in slight glass till i add the freon ,now up to min ,its a old england trailer so its wore out and thats what i have to work with at my company.
  5. reeferwrencher
    572
    1,491
    Aug 4, 2018
    The shaft seal on the compressor is probably leaking.Thats a big job so they'll have to shop it for repair.Sounds like they're due for a new trailer maybe.
    Everett Thanks this.
  6. windsmith
    windsmith Road Train Member
    7,296
    6,031
    Sep 2, 2011
    NEPA
    Did you plug up your drain holes?
    RustyChops41 Thanks this.
  7. truckdriver31
    6,989
    8,352
    Sep 18, 2013
    why are you working on there trailer to start with. let it all melt if they dont want to fix it.
  8. x1Heavy
    x1Heavy Road Train Member
    34,017
    42,137
    Mar 5, 2016
    White County, Arkansas
    Head north, do not stop until Reefer pulls temp you require from a drop in outside temp.
    He he he.
    Get a water hose, spray the entire unit cover off from the front of your trailer.
    The resulting ice covering should cause your engine to find a little more cool to work harder against and boost your temp from 9 down below zero to -5 you seek.
  9. aussiejosh
    aussiejosh Road Train Member
    4,709
    5,409
    Aug 28, 2009
    Airlie Beach QLd
    What can make it tough is if the trailer is really designed for chilled rather than frozen. If the trailer is still attached to the truck/ tractor best thing to do if you not moving is unhook the truck pull it forward that gives the reefer more air to breathe you should see the temps start to come down right away.
  10. ebill45
    ebill45 Light Load Member
    167
    105
    Oct 11, 2011
    dalton ga
    That’s good enough 0 degrees. You going hurt anything at 5 degrees difference. Stop opening the doors or the trap doors. If you must peek inside shut off the unit before u do it. The product is probable sitting at 0 or 5 degrees is why it not dropping lower
  11. ebill45
    167
    105
    Oct 11, 2011
    dalton ga
