A friend has a Freightliner tractor with a Cat 3406 engine. I'm not sure what series it is but the serial
# is 1LW24868 and the tractor is a 1998. It was running and starting fine but last week it wouldn't start after sitting overnight. It cranks fine and has fresh fuel but will only start on starting fluid.
I am not familiar with this engine and can't seem to find the fuel solenoid and am not even sure if that is the problem.
Any help is well appreciated, thanks.
Cat 3406 won't start
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by BobHjr, Oct 10, 2021.
I’d say losing fuel prime, does it have the davco fuel filter, the little butterfly valve can turn a hair and cause it.
It only has one filter, a large clear inverted bowl over a separator. the bowl has a cartridge and also a cap to add fuel. It has a standard hand prime pump. We have pumped the prime up several times, the bowl is full and we can hear fuel returning to the tank when we pump. -
That is a davco style filter... It may be suckimg air past one of the o-rings. Take the bowl off and check the o-ring, if its not torn lightly lube it with clean oil and reassemble. Then fill it with fuel to top of cartrige, when you put the cap back on lube that o-ring aswell.
Ive had davco filters suck air like that before.
If doing that getts it to start let it run for an hour or 2 to make sure it will stay running and not still suck air.
Edit: oh never mind... I see that it is full so it's not sucking air. -
It ran after the filter was changed, it started fine every day for a week, then just wouldn't start. I see no evidence of leakage or such.
Do you know where the shutdown solenoid is. I think the engine may be an early E series but not sure.
Also the engine was washed a few days before the problem occurred. -
E models don’t have a shutdown solenoid, the ecm simply quits firing the injectors to shut it off. Since fuel seems to be ruled out it is an electrical issue may be a timing sensor or wiring. May or may not be related to the washing.
Look at the other threads in the section this is posted you’ll find the wiring diagram for this engine.Caterpillar Cowboy Thanks this. -
If it starts on ether and stays running after I would guess loss of prime. There is a check valve on filter base on driver side of block that likes to go bad. Hard to imagine an emodel not having this filter on it but I have no clue. Good luck trucks that won't start are some of my least favorite ones.
Get it plugged in and see if the ECM is getting speed and engine position signal.
Related Categories
frame crack. how urgent.
4noReason posted Mar 25, 2026 at 7:18 PM -
14L Detroit loss of power and...
Andres Guerrero posted Mar 25, 2026 at 4:23 PM -
Cat 3116 smoking
jagmohannavindra8 posted Mar 24, 2026 at 11:38 PM -
2012 FREIGHTLINER DD15 NO START
PROMOBILE posted Mar 24, 2026 at 11:22 AM -
Rebushing gen 1 vnl torque rods?
Appalachian_Soul posted Mar 23, 2026 at 9:41 PM -
2005 T800 Wiper relay location
Timberwolf9653 posted Mar 18, 2026 -
C15 Acert Transfer Pump
Bentwrench posted Mar 16, 2026 -
System saver 1200
ColumbiaBoB posted Mar 16, 2026 -
1st gen volvo air switch...
Appalachian_Soul posted Mar 15, 2026 -
2005 Kenworth T800 Air Slide
wstinger posted Mar 13, 2026
Loading...
Recent Threads
Haz-mat study guide for Illinois
istumped posted Mar 25, 2026 at 8:43 PM -
Best route
Rideandrepair posted Mar 25, 2026 at 3:49 PM -
Texas DPS Medical Certification
spindrift posted Mar 25, 2026 at 8:40 AM -
Anyone from Texas ?
TruckRanger posted Mar 25, 2026 at 7:14 AM -
Cat 3116 smoking
Education materials
CatAstronautCrew posted Mar 24, 2026 at 11:22 PM -
Dd15 won't complete regen
MTMAUS posted Mar 24, 2026 at 10:58 PM -
suspicious SAIA offer.
OdderThan posted Mar 24, 2026 at 8:08 PM
Loading...
