CAT C13 LOSING PRIME?
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by jazzedman, Oct 23, 2020.
  1. jazzedman
    jazzedman Bobtail Member
    38
    8
    Feb 15, 2019
    Have a Cat C13 in the shop, another guy is working on it, will not start without ether. Once started it will run on it's own but will not accelerate(only gets up to 1000 rpms). Once you shut it off, it will not start again until you shoot it with ether. Doesn't have a primer pump so... We checked the check fuel pressure regulator on the bottom of the fuel filter housing by swapping it with another known good one, no change. No external leaks have been found. Also bypassed the tank and supply line by sucking out of a 5 gl bucket, ran fine and sucked the fuel right up. Any suggestions on what to try next? Thanks!
  3. Judge
    92,171
    Did it start from the fuel in the 5 gallon bucket?
    Fuel line may have collapsed, Most times you see rubber in filter, but not always.
  4. little cat 500
    2,061
    1,109
    Jan 17, 2010
    Abbottstown PA
    probly needs new fuel lines
  5. CountryBumkin
    CountryBumkin Bobtail Member
    43
    39
    Jun 4, 2018
    Are you using a fuel pressure gauge at the "compucheck" fitting? You should see around 65psi fuel pressure cranking.
    Next, disconnect the return fuel line and install a sight glass (or clear piece of hose to a bucket) and start the engine. Are there any large air bubbles showing in the return fuel (indicating a suction side leak)?
  6. jazzedman
    38
    8
    Feb 15, 2019
    No, still had to use ether. Not sure if he found any rubber or even looked. Will ask Monday.
  7. jazzedman
    38
    8
    Feb 15, 2019
    I’m pretty sure he didn’t put a gauge on it. Will be pointing him in this direction Monday. Thanks for the reply.
  8. jazzedman
    38
    8
    Feb 15, 2019
    I’ll definitely give him a heads up. Thanks for the reply.
  9. jazzedman
    38
    8
    Feb 15, 2019
  10. CountryBumkin
    43
    39
    Jun 4, 2018
    Does the RPM gauge register rpm while cranking? If not it is a sign of a bad Camshaft position sensor.
    Also you want to verify that the coolant gauge is reading correctly (if the coolant sensor was "stuck" at 190 degrees, for example, the engine would be hard to start in 30 degree weather, and a code would not be set).
    Lastly, you can test that the fuel injectors are receiving voltage to fire by using an inductive voltage tester (for checking for AC voltage). This tool looks like a pencil shaped device with an led light that lights up when you touch the tip of the tool to a wire with current running through it.
    Google "Adept Ape, Engine Wont Start" on You Tube or use this link
  11. AModelCat
    164,761
    Wonder what your compression will be like after all that ether. Its pretty bad stuff.
