CB antenna help
Discussion in 'CB Radio Forum' started by J_wils9, Dec 12, 2025.
  1. J_wils9
    J_wils9 Bobtail Member
    5
    5
    Dec 12, 2025
    I'm getting a digital cobra 29LX to put in my ford ranger so I can talk to truckers and traffic if needed. I'm looking for a antenna that will work long rang and don't know what would work because I'm still new to all this but would like something under 100 if possible but can go over 100 if needed, Thanks
    blairandgretchen Thanks this.
  3. blairandgretchen
    13,981
    76,901
    Dec 9, 2011
    South west Missouri
    Striker A-10 magnet mount is a good start.
    Get the radio ‘peaked and tuned’ if it can be - or consider buying an older one that has been worked on.
    What’s your 20? There’s still a few good CB shops around.
  4. J_wils9
    5
    5
    Dec 12, 2025
    Thanks I'll grab one of those and see how it goes
  5. blairandgretchen
    13,981
    76,901
    Dec 9, 2011
    South west Missouri
    Actually - skip the magnet mount and get a regular A-10, mount it on a secure bracket at the front corner of the bed, and run a ground wire to anywhere on the frame -
    Get a good quality co-ax , run it back there, should work pretty good.
    Most radio issues are in a poor antenna setup - not the radio.
    High Stepper Thanks this.
  6. blairandgretchen
    13,981
    76,901
    Dec 9, 2011
    South west Missouri
    d o g Thanks this.
  7. blairandgretchen
    13,981
    76,901
    Dec 9, 2011
    South west Missouri
    If you go with the bracket idea - you can get most all the connections from a decent truck stop.
    Better still - a good CB shop can sell you the few parts you’ll need without having to guess on line shopping.
  8. J_wils9
    5
    5
    Dec 12, 2025
    Sounds good I'll make sure to get a mount mocked up for it, then mount it and get a ground. Would the coax that comes with it work so would you recommend buying a different one
  9. J_wils9
    5
    5
    Dec 12, 2025
    You know of any good cb shops around Springfield, Missouri?
  10. blairandgretchen
    13,981
    76,901
    Dec 9, 2011
    South west Missouri
    Yeah - check out the guy at Hoods truck stop west of you. Jim I think. I’ve had work done before with him, he’s good.
  11. J_wils9
    5
    5
    Dec 12, 2025
    I'll go check them out thanks
