Changing a Tire...How many do it themselves
Discussion in 'Experienced Truckers' Advice' started by ultraclassic, Oct 26, 2011.
  1. ultraclassic
    ultraclassic Light Load Member
    205
    71
    Aug 4, 2011
    Oklahoma City, OK
    OK how many out there change their tires themselves if they already have one mounted on a rim? Easy, hard or just time consuming? Also would there be a way to run a air impact off the trucks air system?
  3. Moosetek13
    Moosetek13 Road Train Member
    14,985
    19,038
    Nov 1, 2010
    Burnsville, MN
    How many trucks have you seen with a spare tire mounted to a rim?
  4. Ops85
    Ops85 Light Load Member
    97
    25
    Sep 10, 2011
    Madrid,IA
    too much work
    I've only seen spare tires, especially useful if super single, since roadside service usually only has regular available
    yes, with glad hand adapter
  5. Dna Mach
    Dna Mach Road Train Member
    3,303
    3,152
    Aug 8, 2008
    Texas
    My truck, I would consider it. Someone else's truck, no way. On an outside rim have a big enough block of wood to drive up on. With the proper tools (long enough tire irons) truck tires come right off the rim. Oh yea you still have to seat the bead.....
    The best way
    [ame]http://www.youtube.com/watch?v=ABuvbUIzj2U&feature=related[/ame]
    The correct way
    [ame]http://www.youtube.com/watch?v=TaBXd1RaPr4[/ame]
    I would do none of this. I just call my company and they send someone out. Never a problem as we run good tires and take care of them (small company)
    Schneider and Knight....sit on hold for two hours and the wait 3 or 4 hours for some jerk off too show up and like you ruined his day on purpose.
    Now a question for some of you...just curious why you pull over onto the shoulder of an interstate when you blow a drive or a tandem? That's pretty stupid and places lot's of people at risk. Turn on the 4 ways, slow down and get off the road.
  6. ultraclassic
    205
    71
    Aug 4, 2011
    Oklahoma City, OK
    I've seens lots during my travels up/down the highway with a spare mounted. if it was for the tractor or trailer who knows..Just figured if you didnt want to wait FOREVER as stated above a person could knock it out himself, if practicle. Snap-On ect....are making great cordless impacts that I figure could be used to speed the process...just brain storm'n
  7. SHC
    SHC Spoiled Rotten Brat O/O
    8,484
    7,047
    Feb 26, 2011
    Westville, IN
    I've changed my own tires on the roadside before but never one mounted to a rim, and it was only outside tires, not insides as that would require an impact and removing the lugs/rims which is too much work and I did not carry a jack or impact. An outside tire is easy if u have a pair of vice grips, some motor oil and a 4x8 to drive the inside tire up onto.
    But I have not had to do this since 2005
  8. Blind Driver
    Blind Driver Road Train Member
    3,081
    1,406
    Aug 7, 2006
    New Albany, IN
    This is why I would consider running super singles. A air/hyd jack is wary enough to carry and the wheel wouldn't have to come off of the hub.
    It can be seated with starter fluid and a lighter *BOOM* :biggrin_2559:
  9. SHC
    8,484
    7,047
    Feb 26, 2011
    Westville, IN
    But now you are carrying a jack, and a spare tire. So you can take off some of that weight savings all the guys with SS brag about. Plus when a SS blows out, the rim usually winds up trashed too.
    THBatMan8 Thanks this.
  10. Dna Mach
    3,303
    3,152
    Aug 8, 2008
    Texas
    Yea those SS's are pretty big. I'm starting to see them on the roads now. Just like we knew we would eventually. When a SS treads itself apart that tread is the size of a barrel, might as well be because people are going to do some crazy stuff to avoid them.
    I have limped the short few miles too get service as soon as I have pulled up too the garage far to many times to ever consider super singles. Consider? I should say want...never bought a truck tire in my life and I never will.
  11. WitchingHour
    WitchingHour Road Train Member
    3,425
    2,144
    Apr 1, 2011
    Broomfield, CO
    I've done it before, quite a few times. Don't know how feasible it would be to keep the equipment on an OTR truck... not every tire you have to replace is going to conveniently be an outside drive or trailer tire. It's really not that difficult if you have the right equipment to do it with, but if you didn't know what you were doing beforehand, I'd strongly advise against it - you can tear up a good tire very easily, as well.
