Changing GPS mapping across devices
Discussion in 'Trucking Electronics, Gadgets and Software Forum' started by Binder Minder, Mar 16, 2021.
  1. Binder Minder
    Binder Minder Bobtail Member
    43
    16
    Mar 9, 2014
    Nut Behind the Wheel
    Hi all!
    What’s the best way, if any, to get routing changed on as many GPS platforms as possible? Google Maps? I’m getting feedback on trucks getting stuck/time consuming diversions that GPS’s got them into.
    Thanks in advance!
    Tom
  3. kemosabi49
    10,977
    47,915
    Jan 13, 2013
    SW Arkansas
    Trucks should not use Google maps as the primary GPS. Google maps is great for the satellite views of shippers and receivers but can get a trucker in trouble quick if they use it for their trip plan. They should use one that is made for trucks. Garmin has one and the Hammer app is free.
    Wasted Thyme Thanks this.
  4. Lunatic Fringe
    Lunatic Fringe Medium Load Member
    477
    1,401
    Oct 1, 2016
    All the major platforms are proprietary so you have to get each company to change their routing individually. No, the GPS didn’t get trucks stuck or diverted the drivers did. The GPS is a tool. It is often wrong. It’s up to the driver to use good judgement and overrule the GPS when needed not drive the truck into a river then try to blame the GPS. Another example why trucks won’t be driving themselves anytime soon.
    nredfor88 and shooter19802003 Thank this.
  5. thomasweil
    thomasweil Bobtail Member
    11
    5
    May 12, 2016
    I used Garmin Dezl for years but have switched over to Copilot, which I like because it uses PC Miler; so far, I'm happy with it and use it in combination with Google Maps. I didn't like all the glitches and updates I had to do with Garmin.
    Dieselboss and nredfor88 Thank this.
