CHECK TRANSMISSION (Check yellow light)
Discussion in 'Volvo Forum' started by JobeV, Oct 29, 2022.
  1. JobeV
    JobeV Bobtail Member
    Jul 28, 2022
    I’ve a 2015 Volvo VNL Ishift transmission, couple days ago I got this light on my dashboard, I look up the diagnostic and got
    SA 24 DTC P105378 code, does anyone know what that is? My transmission is running fine, any help will be greatly appreciated, thanks in advance
  3. Judge
    92,066
    That code is indicating a software update
    and cam sensor not reading all the time.
    I suggest replacing the cam sensor, if the issue is still there
    have the ECM flashed and updated.
    I hope this helps you.
    Siinman Thanks this.
  4. JobeV
    Jul 28, 2022
    Thank
  5. JobeV
    Jul 28, 2022
    Thank you, I’ll try that
    Judge Thanks this.
  6. NWAF
    NWAF Light Load Member
    74
    36
    Dec 12, 2014
    Its a code for clutch wear or improper adjustment. No need to touch ECU or Cam Sensor, because neither are on the tranny.
    You need to replace your clutch most likely.
  7. Andythetrucker562
    Andythetrucker562 Bobtail Member
    Did you ever have this resolved??
