Chilled load
Discussion in 'Refrigerated Trucking Forum' started by Snake209, Aug 23, 2020.
  1. Snake209
    Snake209 Bobtail Member
    11
    Aug 23, 2020
    yesterday i Got Loaded and the temperature supposed to be 26 but by mistake i put it on -10 for 24 hours and now I still got 12hrs for delivery and I put it on 26 again so my question is am I going to make thru the delivery or its going to reject
  3. Gdog66223
    Gdog66223 Road Train Member
    1,871
    2,569
    Dec 30, 2017
    Coal Town
    How do you go from 26 degrees to -10. :eek:
  4. 062
    062 Road Train Member
    6,340
    33,984
    Oct 20, 2013
    There’s no way to say for sure either way. A lot of the places I go never check temp recorders.
    bzinger and feldsforever Thank this.
  5. Snake209
    11
    Aug 23, 2020
    Actually this company foster farms i picked up 4 loads with same temp,weight and delivery destination so i thought it's a same load bcoz this time my dispatch didn't mentioned temp in info msg either
  6. Snake209
    11
    Aug 23, 2020
    BUT THE PRODUCT CAN BE AFFECTED IN 24HRS
  7. 062
    6,340
    33,984
    Oct 20, 2013
    At this point it doesn’t matter. You can’t go back in time.
    With that set temp I would guess it’s fresh meat. A Reefer is for maintaining temp not for cooling product. I doubt it brought the temp down more than a couple degrees if at all.
    bzinger and alds Thank this.
  8. Snake209
    11
    Aug 23, 2020
    Temp stayed between 4 to 13 in that time and now since 6pm it's on 26 and yes it's meat load
    bzinger Thanks this.
  9. Snake209
    11
    Aug 23, 2020
    Im worried bcoz it's a damnnn kroger load and in there fix 5 to 8 hrs unloading time they spent 6 hrs to inspect the load
  10. 062
    6,340
    33,984
    Oct 20, 2013
    The only problem you’ll have is if there’s a temp recorder and if they check it. Like I said at this point there’s nothing you can do about it.
    In the future read the bills and if you don’t see a set temp, then ask what to set the unit at.
  11. Snake209
    11
    Aug 23, 2020
    If recorder is the only problem then I can disappear that thing
    feldsforever Thanks this.
