Clicking sound when starting truck, but eventually starts.
Discussion in 'Experienced Truckers' Advice' started by J.S., Feb 20, 2025.
  1. J.S.
    J.S. Medium Load Member
    503
    221
    Jun 27, 2015
    Texas
    I am having a problem. A few times a day I go to start my truck which is a DD 15 and I hear a click noise. I will repeat the star process and most of the time it was then start.. I’m thinking it’s a failing starter, but I’m not sure. Has anybody had these types of symptoms??
  3. Gridaxe5588
    Gridaxe5588 Light Load Member
    128
    170
    Nov 23, 2022
    I have a DD13 and it's not really a click it's like a thud thud thud, been doing it for a few year's now. Had starter checked and was fine, of course it never did it when being checked.
  4. Big Road Skateboard
    7,650
    44,171
    May 2, 2021
    I click when I'm first trying to get started too.
    But sounds like the starter relay clicking. On that truck, it's probably mounted onto the starter solenoid.
    That doesn't mean the relay is the issue, it needs diagnosed, but that's probably what you're hearing
  5. 201
    201 Road Train Member
    12,978
    26,760
    Apr 16, 2014
    high plains colorado
    In the "olde" days, give 'er a rap with a hammer. Today, that would probably get you time in Alcatraz.
  6. Moosetek13
    Moosetek13 Road Train Member
    15,125
    19,294
    Nov 1, 2010
    Burnsville, MN
    Are you turning the key to the on position for several seconds and then to the start position, or straight to the start position?
    Wargames Thanks this.
  7. mustang190
    mustang190 Road Train Member
    2,917
    6,306
    Jan 18, 2011
    Florida Panhandle
    Turn the key to the ON position, count to ten then start it.
    Moosetek13 Thanks this.
  8. Ridgeline
    22,843
    126,181
    First, check/CLEAN all the grounds, especially those going to the engine from the battery or frame.
    Then if this doesn't fix it, replace the starter and the Magnetic starter switch.
  9. Judge
    94,497
    Not helpful… but reminded me of this..
    hope you figure it out…
    The_vett, RockinChair and Gridaxe5588 Thank this.
  10. Iamoverit
    Iamoverit Road Train Member
    2,159
    4,962
    Oct 31, 2023
    Sounds like the starter solenoid is on it's way out but this is impossible to correctly diagnose over the internet. Could be wiring, corrosion, the switch etc etc.
  11. J.S.
    503
    221
    Jun 27, 2015
    Texas
    Thx for the replies but forgot another symptom I’m getting which is if the wipers are left on it’ll click as well. Yes I do let the truck cycle before I start it. It’ll start with the a/c on but twice I’ve left the wipers on and again got a click. Turned it off and back on and it will start. Kljust don’t want be somewhere and it stops starting all together.
