clutch question
Discussion in 'Questions From New Drivers' started by ad356, Dec 22, 2021.
  1. ad356
    ad356 Road Train Member
    2,138
    3,179
    Mar 13, 2017
    i always wondered is it better to just keep the clutch pressed in at an intersection when stopped, or put the truck in neutral and only put it in gear when the light changes? im under the impression is easier on the throw-out bearing and clutch if you leave the truck in neutral until light turns green. does it make a difference?
    Dino soar Thanks this.
  3. Dave_in_AZ
    424,195
    Lot easier are on the leg. Plus you don't have to worry about accidentally dumping the clutch or having it engage for whatever reason when you might not be ready, and having it whack the vehicle in front of you.
  4. Brandt
    Brandt Road Train Member
    4,624
    6,359
    Sep 17, 2012
    I never heard of putting it in neutral at lights to save throw out bearing. Seems like doing that would cause more wear on the clutch brake.
  5. AModelCat
    164,644
    The throw out bearing is spinning all the time anyways. Its just under a bit of load when you have your foot on the clutch rather than free spinning.
    Rideandrepair and InTooDeep Thank this.
  6. pavrom
    pavrom Road Train Member
    3,216
    7,408
    Apr 29, 2012
    NE illinois
    Neutral ...or clutch brake gonna be replaced more often
  7. Frank Speak
    Frank Speak Road Train Member
    4,583
    14,117
    May 3, 2016
    Do one for 6 months and then the other for 6 months and come back here to report your findings.
    Rideandrepair and homeskillet Thank this.
  8. Numb
    Numb Crusty Curmudgeon
    4,318
    10,253
    Jan 30, 2012
    Charlotte, N.Carolina
    have never put it in neutral at lights , never had clutch problems.
    500K same clutch on many trucks
    was told yrs ago, if you did that you were not in control of your vehicle.
    light turns green I want to go, not wait for you to find a gear and go.
  9. Brettj3876
    Brettj3876 Road Train Member
    11,257
    54,060
    Nov 18, 2014
    Land of local
    I did that before when the rubber pad slipped off the clutch pedal. Gotta be quick with the wit to save it. Turned the key off a a millisecond before it slipped. It only lurched a little bit instead of smashing the car in front of me
  10. special-k
    special-k Road Train Member
    1,523
    3,258
    Dec 27, 2008
    Southern Ontario Canada
    Imo you would be right. Bitd that was hammered into me when l was learning. Put it in gear when the cross light goes yellow. Plus no worry of foot slipping off the clutch pedal and launching it into the car ahead if you. Plus l find it's too easy to get it into the clutch brake if you are sitting there with the clutch in. That's just me though.
    Rideandrepair Thanks this.
  11. Dino soar
    Dino soar Road Train Member
    4,815
    27,071
    Dec 8, 2017
    Myself I always put it in neutral.
    Maybe it is negligible but when you hold your foot on the clutch you're actually using the Springs in the pressure plate.
    I'm sure someone is going to laugh and say they're heavy duty Springs you can't do anything to them!
    Maybe maybe not but if you think about it when you put your foot on the clutch and put it in gear and pull out, those Springs are engaged for a minimal amount of time. If you then shift without the clutch, again, no usage.
    If you stop for a lot of lights and at every light you hold the clutch in 3 minutes here, 3 minutes there, 4 minutes there, it adds up.
    By the way on a driving test they will fail you instantly for that.
    And as far as clutch brake goes use a two piece and you can change it in a few minutes.
