Cold start engine knock
Discussion in 'Ask An Owner Operator' started by Keepforgettingmypassword, Oct 19, 2022.
  1. Keepforgettingmypassword
    Keepforgettingmypassword Heavy Load Member
    738
    938
    Jan 11, 2022
    I let it sit for 2 or 3 rainy days. I fired it up and it knocked about 6 times. Also a sinificant amount of decrease in mpg.
    Could these 2 be related?
  3. Judge
    92,482
    mainly the cause is either carbon buildup, valve, worn-out bearing piston slap, and worn-out engine parts. There are probably more, but these are well-known causes.
  4. Brettj3876
    Brettj3876 Road Train Member
    11,257
    54,060
    Nov 18, 2014
    Land of local
    Engine make would be helpful
  5. Keepforgettingmypassword
    738
    938
    Jan 11, 2022
    2016 DD 13. 5 clynder cascadia
  6. W923
    W923 Road Train Member
    1,422
    4,408
    Feb 28, 2022
    Not sure about your particular engine but generally that’s a sign of injector problems and I have heard some injector knocks that you would think were metal parts hitting they sounded that bad
    Is there any smoke?
  7. Keepforgettingmypassword
    738
    938
    Jan 11, 2022
    No smoke just 4 or 5 knocks then stopped. Hasn't happened again.
    W923 Thanks this.
  8. baha
    baha Road Train Member
    4,137
    2,837
    Jul 25, 2013
    ga
    1 over fueling injector can make sounds like you are hearing?
    Keepforgettingmypassword and W923 Thank this.
