Cold weather MPG sadness
Discussion in 'Ask An Owner Operator' started by shatteredsquare, Jan 7, 2020.
  1. shatteredsquare
    shatteredsquare Road Train Member
    1,407
    1,841
    May 23, 2014
    middle dirt
    If the whole point of a cold air intake is to cool the air prior to ingestion, so it's more oxygen dense, then why tf does the MPG go kaput in the winter. Shouldn't the engine be stronger sucking cold air?
    1 mpg difference over a week is like +250 bucks...:(
  3. Hulld
    Hulld Road Train Member
    2,884
    6,568
    Oct 19, 2015
    Upstate NY
    Think of all the extra resistance there are on cold turning bearings and cold thick oils among other things such as blowing head winds and idling to stay warm to name a few.
  4. Chubby Fly
    Chubby Fly Medium Load Member
    569
    797
    Nov 25, 2019
    In off road conditions, the crossmember bolts get loosened up. BEfore retightening, take those out and replace them with fine thread flange bolts class 10.9 or grade 8. Say goodbye to a boring life
    PE_T and D.Tibbitt Thank this.
  5. GFTLLC
    GFTLLC Light Load Member
    75
    80
    Jan 4, 2020
    Pennsylvania
    I've seen on here in several places that the winter blend fuels will cause a .5 or more mpg decrease. I actually just asked this in a different thread and someone posted that mpg will rise in the summer due to the fuel mix. Kerosene was also mentioned there. The post is in ask an owner operator under poor fuel mileage.
    Rickp, PE_T, D.Tibbitt and 1 other person Thank this.
  6. Anywhichwaybutloose
    Anywhichwaybutloose Light Load Member
    159
    265
    Jun 24, 2017
    Due to a mix of # 1 and # 2 diesel. The more #1, the colder you can go but MPG goes down. Beats gelling up.
    Long FLD, bzinger, PE_T and 4 others Thank this.
  7. The Biggest Dawg
    The Biggest Dawg Light Load Member
    177
    99
    Oct 16, 2019
    [Location Not Found]
    This is the correct answer. I used to deliver diesel.
    starmac, bzinger, PE_T and 3 others Thank this.
  8. blairandgretchen
    13,973
    76,842
    Dec 9, 2011
    South west Missouri
    Mine usually tanks .5 to 1 mpg in the winter. I track my fuel tank to tank - last 5 years, religiously. Never fails.
    bzinger, Rubber duck kw, PE_T and 2 others Thank this.
  9. Midwest Trucker
    5,914
    21,390
    Aug 31, 2018
    Yeah kinda sucks all around. Winter fuel is less efficient, but hopefully your bunk heater will off set that. Summer fuel gets better mileage, but you may see more idle which off sets it. ####'d if you do, ####'d if you don't.
    bzinger, PE_T and D.Tibbitt Thank this.
  10. D.Tibbitt
    157,286
    I got 2mpg running thru a nice 40-50 mph headwind in south dakota last weekend . Had the pedal on the floor and couldnt get it out of 11th gear .
    Dave_in_AZ, bzinger and PE_T Thank this.
  11. LDLWells
    LDLWells Heavy Load Member
    782
    1,219
    Jan 14, 2019
    It stays 4.5mpg year round. Just start hauling 120k gross and you won't even notice
    dosgatos, AModelCat, D.Tibbitt and 3 others Thank this.
