Combine compartments?
Discussion in 'Refrigerated Trucking Forum' started by Elroythekid, Feb 18, 2022.
  1. Elroythekid
    Elroythekid Road Train Member
    2,620
    5,675
    Sep 9, 2010
    Halifax Nova Scotia
    I'm new to reefer...
    I have a carrier 3 compartment trailer.
    Temps are 36 -5 36
    Center unit is not defrosting, service guy said 2 sensors are reading wrong, no parts, has to be mty to fix anyway.
    I got my first drop off. Rear compartment and 3 skids from center.
    Can i just leave the wall down and set the end compartment same as the middle? If the middle gives up the rear will help it along?
    I'm sleeping on this tonight, then 2 more drops.
    Thanks.
  3. Elroythekid
    2,620
    5,675
    Sep 9, 2010
    Halifax Nova Scotia
    It worked, both zones now at -8 all night, and it didnt throw any failed defrost alarms.
  4. roddy55
    roddy55 Bobtail Member
    21
    23
    Jul 22, 2021
    Old thread... But its worth a reply as its a fairly common.
    Glad it worked out for you.
    You did the right thing pulling the cold wall down.
    Was it in continuous run or start stop? As defrost requires compressor running.
    If center load is wet or not frozen completely the evaporator will freeze up and need frequent defrosts. Multi temp evaporators are small and don't have have much real-estate, lending themselves to icing up. Sometimes its good idea to manual defrost before/while loading to give you an edge.
    TK or Carrier? Not all multi temp reefers can heat, defrost, and cool at same time. It depends on the options chosen when purchasing unit. Its possible that center unit has to wait for front evaporator to enter defrost mode. Contact manufacturer with model and serial numbers to find out exactly its capabilities.
    I preferred old style TK 3 zone controls with off/on toggle switch for each zone. The logic of zone controls seemed clear.
    The 8 new button control panel starts to get confusing with 3 or more zones when your having problems.
  5. Elroythekid
    2,620
    5,675
    Sep 9, 2010
    Halifax Nova Scotia
    Had a tech come look at it and he said 2 sensors on the middle zone (freezer) were toast, one reading -50 the other +50. He had no sensors, thought it "might" be ok. I had the doors open doing the first drop and it was a rainy humid night, LOTS of rain. After the first drop the rear section was empty so I had the bright idea to change that zone to freezer also. It worked overnight it cooled back down and was -8 in the am. After the second drop it was still ok but all 3 zones had gone into a defrost between the 2nd and last drop and wouldnt come out of it, but I got it off before temps got too far out of range.
  6. roddy55
    21
    23
    Jul 22, 2021
    Welcome to multi temp reefer madness!
    2nd and 3rd evaporator temperature sensors tell temperature at evaporator, NOT necessarily the loads circulating air temperature.
    Get couple temperature probes to verify compartment temperatures.
    If running start stop mode make sure the temperature start and stop are OK for each zone
    Your going to have to baby sit reefer until figuring out its idiosyncrasies. Downloading reefer data and reviewing it will give you a good idea of temperature holding characteristics.
    Multi temps have many things affecting compartment temperatures. Most important is cold wall, don't skimp on quality wall and keep sealing areas it in good repair. Even small leak between front compartment will make 2nd compartment too cold, 2nd evaporator temperature reading may NOT reflect temperature at floor. Things will change depending on outside temperatures.
    Also air circulation is poor with ceiling evaporators compared to front unit. When loading take air circulation into account!.
    In winter be careful with loads requiring heat as ceiling evaporators fans don't blow hard and temp sensors at ceiling not at the trailer floor.
    Keep ceiling evaporator drip trays drains clean and hoses angled down.
    Get a produce temperature chart and know what products cant be shipped together like apples and bananas etc...
  7. abyliks
    abyliks Road Train Member
    4,138
    9,743
    May 2, 2010
    ludlow MA
    Unless it’s ice cream, I would of just set it to 15* and let it all ride
