Continues or start and stop
Discussion in 'Refrigerated Trucking Forum' started by broadway3k, Jun 16, 2023.
  1. broadway3k
    broadway3k Bobtail Member
    Hello everyone
    I have a question about reefer loads. I am new in reefer game. Almost all loads I am picking up broker says continuous temperature. What do you guys think if broker says 35F continues, should it be okay to keep 25F at start and stop ?
  3. keebler13579
    keebler13579 Heavy Load Member
    994
    1,986
    Nov 16, 2012
    No if something happens and the data says it was on start stop it will be your fault
  4. buddyd157
    buddyd157 Road Train Member
    13,582
    34,899
    May 25, 2017
    under a shade tree
    do as you are told.
    as the broker is relaying THAT information from the customer(s)
    mess around and it's your butt in the sling.
    bzinger Thanks this.
  5. northstarfire0693
    northstarfire0693 Heavy Load Member
    865
    598
    Jul 1, 2006
    NC
    Do what the broker wants. Also if your hauling produce, use continuous. As long as you follow instructions by the broker, you are good.
    bzinger and buddyd157 Thank this.
  6. Magoo1968
    Magoo1968 Road Train Member
    2,061
    5,492
    Mar 18, 2021
    St Malo mb
    Batteries get weak starters fry sensors go bad all of which could prevent reefer from starting . If it’s already running you’re safe . Tbh you really don’t safe much fuel because on cycle it starts and runs full blast where on continuous it may idle steady .
    jbatmick Thanks this.
  7. TruckerPete1990
    TruckerPete1990 Road Train Member
    8,623
    5,382
    Jul 16, 2012
    Bentonville Arkansas
    No run it where the Bills say otherwise you can be held liable for damages. Some loads even have temp recorders in the pallets so they can confirm what the temp was.. Last thing you wanna do is mess around with a claim
  8. abyliks
    abyliks Road Train Member
    4,142
    9,770
    May 2, 2010
    ludlow MA
    Depends on what it is, I usually just run 0, or 15 if I have a mixed load on start/stop, if it gets over 80 I run continuous so it can just idle.
    I don’t do produce or ice cream though, nor truckload brokered stuff, so follow what the bills say,
  9. aussiejosh
    aussiejosh Road Train Member
    4,798
    5,649
    Aug 28, 2009
    Airlie Beach QLd
    The key to remaining employed is following directions, especially with controlled temperatures, and products that are sensitive to what temps they are stored at, running a load at 25 °f will not be good for that particular product if your going to use the stop / start option I'd set the temp maybe only a few ° f below at most say around 33 °f. That way it is still pretty close to the mark whereas 25 °f is far too cold and is well below freezing point, whereas 33° f is still above freezing, so less chance to damage produce. But really you should try and maintain the recommended temp when you get to the delivery point and they do a temp check this is where you could come undone if you were running it to cold, they will of course report this to the shipper, who will find out who the transport company was, and they in turn will come looking for you. So if you were going to run it a little cooler try and reset to the right temp at least 5 hours before you arrive at the warehouse so it will be pretty close to the right temp. Otherwise the best option is just set it to the specified temp requested and leave it there not sure what your issue is with continuous run? Does the noise bother you? If it is maybe reefer is not the best option for you and you might be better off doing dry van.
  10. Avrakotos
    Avrakotos Medium Load Member
    366
    579
    Jan 22, 2020
    BC
    I run reefer produce for a 3pl. 100+ loads a week. we never ever ever run start stop... ALWAY RUN CONTINUOUS NO EXCEPTION UNLESS SPECIFICALLY INSRUCTED (AND YOU WONT EVER BE INSTUCTED TO). So dont #### around trying to be cute and running it on start stop. Customer will 100% find out and you will get a claim. Every load runs with a temp recorder. Your insurance will deny it and my legal team will take you to court for that full claim amount if you dont have 50k claim to just hand over to us or the customer.
  11. abyliks
    4,142
    9,770
    May 2, 2010
    ludlow MA
    I’ll grab a dry load before I do produce, or ice cream for that matter
