Continuous.
Discussion in 'Refrigerated Trucking Forum' started by janny, Dec 19, 2020.
  1. janny
    janny Bobtail Member
    7
    Sep 19, 2010
    Libertyville, il.
    I have 06 carrier xtc. Starting cycle mode , then unit works like continuous. Panel shows cycle but it is working continuously in any weather. Pre trip however shows Pass.
  3. reeferwrencher
    reeferwrencher Medium Load Member
    613
    1,577
    Aug 4, 2018
    So are you saying it s on start/stop mode and it isn't shutting off when reaching set point?
  4. janny
    7
    Sep 19, 2010
    Libertyville, il.
    Yes, and still runs like continuouse .
  5. 062
    062 Road Train Member
    6,338
    33,982
    Oct 20, 2013
    What does it show the battery voltage is? Thermo king won’t shut off if voltage is low.
    ready2truck and bzinger Thank this.
  6. janny
    7
    Sep 19, 2010
    Libertyville, il.
    Well, battery is like 3 weeks old and alternator works fine. Checked voltage - no problems. Starter works properly too.
    One more thing, if I set 0F for example ,it keeps running slightly lower, like -2F and stays there.
    Pre trip - pass. Status -Ok.
  7. wichris
    wichris Road Train Member
    4,509
    9,288
    Jan 17, 2011
    If the set point is low enough it will run continuous.
  8. janny
    7
    Sep 19, 2010
    Libertyville, il.
    Load of potatoes, 42F inside, 44F outside. Still the same thing.
    tscottme Thanks this.
  9. reeferwrencher
    613
    1,577
    Aug 4, 2018
    If the battery is ok check the water temperature if the sensor is reading too low it will never shut off it should be above 150 f
    bzinger and 062 Thank this.
  10. Six9GS
    Six9GS Road Train Member
    1,473
    3,697
    Dec 3, 2012
    Yuma, AZ
    I work for Swift. We have mostly Thermo King units and some Carrier ones too.
    At certain set temperatures, it automatically stays in continous mode and will not cycle or let you change to cycle mode. 34° is one of these odd set points thay does it. -10 will cycle if you want it to. Unsure of all the set points that won't operate in cycle mode. Also, unsure if this is a setting done by our company or if all the ThermoKing and Carrier reefers are set like this.
  11. abyliks
    abyliks Road Train Member
    4,141
    9,770
    May 2, 2010
    ludlow MA
    my 210 will cycle at -10....I’ll flip continuous once a day for an hour or so though in this colder weather to keep the battery charged
    edit: just noticed he said carrier and not tk, which I’m pretty sure the last rental I had last year also cycled at the same temp
