Crews working to clean up 200-gallon fluid leak along I-70
Discussion in 'Trucking Accidents' started by RhodeGuy762, May 28, 2026.
  1. RhodeGuy762
    RhodeGuy762 Light Load Member
    52
    166
    Mar 29, 2026
    Rhode Island
  3. Bud A.
    Bud A. Road Train Member
    3,502
    25,701
    May 10, 2015
    Mountain Time
    I wonder what happened. He was probably going pretty slow at that point if he was loaded.
  4. Arctic_fox
    4,808
    27,518
    Sep 16, 2016
    My guess is he was texting. Drifted off the road got the tank sloshing, tried to recover, slowed hard as he tried to do so, and was sent into the ditch when the slosh pulled it over which caused more sloshing and over she went. Keep in mind most bulkheads and baffles are front to back, not side to side. And this happened several times out in the oilfield. Same thing, tank got out of control, driver tried to slow. Slosh pulled hin into ditch which made it worse. Then slosh yanked it over
  5. hope not dumb twucker
    6,369
    55,537
    Aug 23, 2022
    Wait slowing down made it worse? I genuinely don’t know haven’t hauled tanker.
  6. Long FLD
    Long FLD Road Train Member
    13,450
    57,141
    Mar 4, 2015
    A 4 or 5 compartment fuel trailer doesn’t slosh much unless you’re running around with half a load on. I have a 4 compartment that’s 9800 gallons and even with 8500 gallons on you can’t feel it slosh, or with 7500 of diesel because the 3 compartments I load are mostly full.
    RhodeGuy762, mjd4277 and Bud A. Thank this.
  7. Arctic_fox
    4,808
    27,518
    Sep 16, 2016
    Fair. Ive never hauled fuel only water, oil, condensate ect and those all handle much diffrent to fuel from what ive heard. Regardless side slosh is the best answer i got for what happened.
  8. Antinomian
    Antinomian Road Train Member
    2,229
    3,593
    Feb 17, 2013
    It only spilled 200 gallons? That's seems like a win.
    RhodeGuy762, Bud A. and Long FLD Thank this.
  9. Long FLD
    13,450
    57,141
    Mar 4, 2015
    That’s what I was thinking. Going west one would assume he was loaded out of Denver and it would appear everything on the trailer worked as it should.
    Bud A. Thanks this.
  10. Long FLD
    13,450
    57,141
    Mar 4, 2015
    Most of your compartments will be full or close to full with a fuel trailer. A daycab like that can probably haul 9k gallons legal and that’s probably a 9200 or 9500 gallon trailer he’s pulling.
    My trailer is 3000/2000/1600/3200 and my first load this morning was a two drop that I had to load 2000/1900/1500/3100 and that little extra room in the front isn’t even enough to be able to feel the trailer when the other three are full.
