Cummins ISC - 700k miles
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by Mach, Sep 3, 2020.
  1. Mach
    Mach Light Load Member
    186
    141
    Nov 19, 2017
    Knoxville Tennessee
    So a buddy of mine pointed to a truck that fits what I need perfectly in terms of how it's built. It's a 2009 kenworth T370 with the 8.3 ISC. The truck was deleted of emissions in 2011 and currently has 717k miles. The original owner has owned it since new and has kept logs of everything done to the engine. Oil is changed every 10k miles and is constantly doing early preventative maintenance. He says he'd drive it to a million miles with no concerns. Turbo was replaced at 600k miles.
    So how good are these engines? Do they usually last this long with now major rebuilds? I haven't gotten to see it in person yet but the seller claims there is no oil leaks or blow by of any kind. Doesn't use coolant and never gets hot. He ran expedite hotshot work and rarely had more than 15k lbs on the deck. Which means the truck moved around at a average of 26k lbs. Has a eaton 10 speed behind it with a brand new clutch.
    So what do you guys know? If y'all recommend a rebuild, about what does that run?
  3. Judge
    92,297
    Depends on the price of the truck, if you can get it cheap enough and want to do an inframe
  4. spsauerland
    spsauerland Road Train Member
    4,296
    10,891
    May 31, 2010
    West Harrison, In
    The ISC does have wet liners, so it is inframe rebuildable. I always thought they were solid engines.
  5. Mach
    186
    141
    Nov 19, 2017
    Knoxville Tennessee
    The truck is listed at 28500. And it's good to hear that it can be done in frame. That's saves a ton Right there. I know over seen people that say they are running strong at 700+ and some into the million range with out ever being touched. I just want to see if I could get some other opinions. Might see if the dealer could quote an In frame rebuild that way I can just roll it into the financing.
    Also what's a safe option to getting a little more power out of these. This one is a 330 horse and I think 1000ft lbs? I'm mostly looking to get a little more on the torque side but nothing wild. Do I need it? No. But if the engine were to be rebuilt, a little more extra power would be nice.
  6. magoo68
    magoo68 Road Train Member
    3,393
    5,385
    Jun 11, 2011
    st malo mb canada
    Dealer might not be allowed to rebuild that engine. It might need to be done at a outside shop due to the delete.
    Goodysnap, bzinger and spsauerland Thank this.
  7. Mach
    186
    141
    Nov 19, 2017
    Knoxville Tennessee
    Good point. I know the place it's being sold at is a used truck dealership / full service shop. But if that doesn't work, there's a handful of reputable diesel shops near me that could probably do it easily.
  8. spsauerland
    4,296
    10,891
    May 31, 2010
    West Harrison, In
    Price seems a little high.
  9. Judge
    92,297
    I’ve always had good service from Cummins, the one I just sold had 909k and would start with just a bump of they key. It was an ISX though, and I’ve had
    N-14s
    I’d buy another Cummins engine.
  10. Mach
    186
    141
    Nov 19, 2017
    Knoxville Tennessee
    Price is a little high for what it is, but finding a truck built exactly the way you need it with the proper engine and trans is hard to do. At least for straight trucks with a sleeper and flatbed. I'm willing to pay a little extra to save me from having to modify a completely different specd truck.
    And cummins has always treated me well. My go to engine. I called the dealer and they can do a In frame rebuild. So I will debate that. But seeing that the engine doesn't leak, or burn oil and coolant. I may leave it as is. I'll have to drive it and take a good look in person when I do.
  11. AModelCat
    164,847
    If it ain't broke, don't mess with it.
    magoo68 and spsauerland Thank this.
