Cummins N14 Long Crank Tried the Norm
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by MvFab, Jan 13, 2022.
  1. MvFab
    MvFab Bobtail Member
    9
    8
    Jan 13, 2022
    I have a N14 Celect+ it takes about 15secs cranking to start once going runs perfect, we have changed the ECU cooler plate, installed 2 back flow restrictors one at pump one at tank, new fuel shut off. Nothing has changed the long crank, No codes in ECM, ECM was replaced for a unrelated issue but it didn't change the long crank. any Help would be greatly appreciated
  3. 062
    062 Road Train Member
    6,402
    34,247
    Oct 20, 2013
    Have you checked the fuel pressure? It takes over 20psi before the injectors fire.
  4. MvFab
    9
    8
    Jan 13, 2022
    While cranking, While Running, Or static when off, We haven't checked pressure... didn't go that route because once running shes a work horse runs great, the long crank has only become a real issue because its winter , so in that fact the pump is working fine, we were under the impression that its bleeding down that's why we went the route we did
  5. johnnyhaulin
    johnnyhaulin Bobtail Member
    10
    May 13, 2014
    I had the same issue with mine. There is a filter in the side of the head if you follow it up from the injector pump (drivers side) it's right in the middle. My mechanic told me there's a filter inside and he cleaned it out. I turned mine over count to about 3 to 5 seconds it starts right up now. I hope this helps.
    stuckinthemud and Coffey Thank this.
  6. blairandgretchen
    14,045
    77,553
    Dec 9, 2011
    South west Missouri
    Do you happen to have a picture?
    My buddy has the long crank issue with his, and we've tried about everything.
  7. MvFab
    9
    8
    Jan 13, 2022
    I think hes talking about the one in the cooler plate, and we have replaced the compete cooler plate so I don't think that's the issue the fuel line from the pump goes to a hard line the enters the rear of the head
    blairandgretchen Thanks this.
  8. blairandgretchen
    14,045
    77,553
    Dec 9, 2011
    South west Missouri
    I thought so. the one behind the cooler plate is a check valve?
  9. MvFab
    9
    8
    Jan 13, 2022
    Just Pulled filter/screen out of fuel pump (top of pump toward mounting flange under big flat head screw) perfect condition no metal no build up cleaned installed still long crank...ahhhhh
  10. 062
    6,402
    34,247
    Oct 20, 2013
    While cranking.
  11. MvFab
    9
    8
    Jan 13, 2022
    also In my case we have check valves at pump, at cooler and at tank pick up.. the tank one was my idea normally everyone has one at pump and in cooler plate.. but still long crank and no different than without any of the added check valves.. just a note
