DD13 recommended oil
Discussion in 'Ask An Owner Operator' started by crucar1800, Apr 20, 2019.
  1. crucar1800
    crucar1800 Light Load Member
    188
    72
    Sep 21, 2012
    Recently someone said that Detroit diesel engines should use Mobil delvac oil. Personally, using shell rotella seems a better choice considering it has superior quality. Is it true that a dd13 engine must use Mobil delvac instead of any other?
  3. Gentlemanfarmer
    Gentlemanfarmer Medium Load Member
    365
    384
    Feb 26, 2010
    Greenville, FL
    Really your choice. If you like Rotella, use Rotella. If you prefer Mobile Delvac, use that. Both are high quality engine oils designed for todays diesel engines.
  4. mover man
    mover man Road Train Member
    1,698
    1,801
    Feb 21, 2010
    It comes with Delvac from the factory. The label on side of engine says use Delvac.
    I used rotella in my Cummins.
    Switched to delvac when I bought a truck with a Detroit.
    Tried using rotella in it, but it burned it up, so I had to keep adding oil. (I'm not a mechanic and my opinion doesn't count for squat. But i think rotella is to thin)
    Switched back to delvac that problem went away.
    One time at a Petro, I put in delo in by accident, didnt have any problems or extra burn.
  5. D.Tibbitt
    157,290
    Well it don't really matter if u got a Detroit , the #### is just gonna leak out in 2 days lol
  6. crucar1800
    188
    72
    Sep 21, 2012
    Yes. Tib it does have the tendency to sweat oil vapors around which will turn into leaks. Imagine if synthetic oil was used on this type of engine. Leakcadia.
  7. crucar1800
    188
    72
    Sep 21, 2012
    Thanks mover. This truck does not have a label that reads use mobil; instead, there is a label that says use oil that complies with API 4. I would think that these type of oil are rotella T4, Delo CK4 and Mobil delvac 1300. Mobil does not say 4 anywhere, but the label talks about it. Not very convincing to my perception of Mobil.
  8. crucar1800
    188
    72
    Sep 21, 2012
    I agree with you farmer. The reason I ask the community is because I was told that the engine is designed to work with Mobil. I disagreed, but didn't want to say anything because Mobil is good oil, but not to the point to cast a shadow over the competition. All three major brands are strong. I like Chevron Delo that oil holds on a Cummins well during the summer with no Lucas.
  9. uncleal13
    uncleal13 Road Train Member
    3,797
    6,299
    Apr 9, 2009
    Humboldt, Sk
  10. crucar1800
    188
    72
    Sep 21, 2012
    Thanks uncleal. This information is very useful.
  11. snowwy
    snowwy Road Train Member
    20,612
    13,333
    Jul 6, 2009
    The ISX. Prefers delvac or delo. And the model years I drove. Had a label on the frame stating delvac.
    Smooth running engine. Less gasket leaks. Better mpg. Runs cooler and cools down faster. Slowest consumption.
    Nothing else really works. Unless you don't mind a noisy engine, and adding oil and spending more on fuel.
    I don't know about the detroit and cat engines.
    crucar1800 Thanks this.
