DD15 cold start issues
Discussion in 'Freightliner Forum' started by Mike_smitz, Jan 3, 2020.
  1. Mike_smitz
    Mike_smitz Bobtail Member
    4
    6
    Jan 3, 2020
    I've got a dd15 (2007) that refuses to start in the cold anymore. I have a block heater working and it's always been good till this fall and winter. It used to start at minus 10 without being plugged in no problem. Now, plugged in I can't get it to start at 0. I've been putting it in my heated shop every night and it starts right up. What do you thinks going on. I'm baffled as I thought fuel was leaking back but if it can sit in my shop for days and not hesitate to start but 3 hours in the cold it just cranks and cranks. Thanks.
    Upinsmoke and uncleal13 Thank this.
  3. 062
    062 Road Train Member
    6,338
    33,982
    Oct 20, 2013
    @mhyn is knowledgeable on the dd motors. If it’s not a fuel problem. My guess is it doesn’t have the compression to ignite the fuel. Does it have a lot of blowby?
    Upinsmoke Thanks this.
  4. 4noReason
    4noReason Road Train Member
    2,401
    757
    Nov 29, 2012
    i had same issue. dd15. they changed my srs sensor
    Upinsmoke and Mike_smitz Thank this.
  5. Judge
    92,558
    I don’t blame it, it’s hard to get motivated when the is no temperature outside or even less.
  6. Mike_smitz
    4
    6
    Jan 3, 2020
    Just picked a new one up since you told me. I will let ya know tomorrow. But does make sense when ya look it up and the parts guy said yep probably the problem.
    062 and Upinsmoke Thank this.
  7. Mike_smitz
    4
    6
    Jan 3, 2020
    It does have blowby but not much. Like not crazy but a little yep.
    062 Thanks this.
  8. Mike_smitz
    4
    6
    Jan 3, 2020
    Hahahaha probably the problem yep, but it's hard enough to get me motivated let alone have my employee slacking as well..
    Judge Thanks this.
  9. mhyn
    mhyn Road Train Member
    4,255
    4,515
    Dec 29, 2008
    Northridge, CA
    first must be checked all active and historic codes. if no fault codes then rail pressure during starting. if ril pressure is ok idle speed balance test must be done to see low compression cylinders exist.
    I think in your case fuel is going back to tank when its cold outside. could be worn bypass valve in fuel filter housing..
    062 Thanks this.
