ddec 3-4 12.7 whistle while under load when building air.
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by dberset, Oct 23, 2022.
  1. dberset
    dberset Light Load Member
    75
    35
    Jan 12, 2020
    I have a ddec 3-4 12.7. I’ve had a whistling noise for about two years that I’ve been trying to nail down. Yesterday I noticed that it will only do it when the compressor is building air. It will only happen under moderate to full power, not at idle. I have changed the hose from the intake to the compressor a few months ago with no change, still happens. Now I noticed it was only when building air. Any ideas? Is there a direct path for boost pressure through that intake hose out through the safety valve when the governor calls for air? That is the only thing I can think of.
  3. blairandgretchen
    13,951
    76,726
    Dec 9, 2011
    South west Missouri
    I’ve had that high pitch whistle from boots not clamped tightly.
    I think there is a torque down procedure for them to stretch and seat.
    Have you eliminated the boots?
  4. Bean Jr.
    Bean Jr. Road Train Member
    5,573
    9,929
    Mar 30, 2014
    I would look at your airlines from the compressor to the dryer. My guess is that you've got a leak in that line.
  5. dberset
    75
    35
    Jan 12, 2020
    I need to add one more thing that you should know.
    The whistle noise is variable with your foot input. It’s not. Constant unless you’re hammer down.
    Bean Jr. Thanks this.
  6. dberset
    75
    35
    Jan 12, 2020
    Noise only occurs when compressor is building air. As soon as it purges the whistle stops.
    blairandgretchen Thanks this.
  7. baha
    baha Road Train Member
    4,137
    2,837
    Jul 25, 2013
    ga
    CK the flex part of air line coming out of air compressor it will only leak when it's building air and will leave you on the side of the road when it gives up! And is a shut down if you have a dot inspection?
    dberset and Bean Jr. Thank this.
  8. dberset
    75
    35
    Jan 12, 2020
    that makes sense. It would have a direct path from the turbo to the air dryer when building air. Ill investigate. Thanks
  9. Bean Jr.
    5,573
    9,929
    Mar 30, 2014
    But if it's leaking, it will leak whether the compressor is cycling or not. Remember, just like the turbo is providing boost to the engine, it's providing boost to the compressor.
  10. dberset
    75
    35
    Jan 12, 2020
    I’m going to take a dive into it when I get home maybe it’ll put out enough air with the red knob pushed in at 1000-1200 rpm to find a leak with soapy water. I’ll give it a visual tomorrow also in the daylight.
    Thanks again for the insight. I would have never even went in that direction.
  11. BoxCarKidd
    BoxCarKidd Road Train Member
    4,551
    6,641
    Aug 26, 2014
    ? When the compressor is not building air are the intake valves not held open and the exhaust valve stay closed. No air would go to the outlet hose unless the exhaust valves are bad.
    Air from the governor opens the intake valves but also unloads the dryer. Would the compressor outlet line not be relieved of pressure?
    If not the discharge line could it not possibly be the dryer?
