DEF into Diesel Engine
Discussion in 'Trucks [ Eighteen Wheelers ]' started by bertramnet, Mar 14, 2021.
  1. JonJon78
    JonJon78 Road Train Member
    7,241
    43,016
    Jul 1, 2018
    How often has your shop come across this type of situation?
    Goodysnap Thanks this.
  3. Goodysnap
    Goodysnap Road Train Member
    3,771
    9,195
    Jul 12, 2017
    Its is not super common. Over the years Id say I have had about 12 or so cases of Diesel contaminated with DEF.
    Can be very hard to detect if nobody fesses up.
    See alot with Gasoline contamination as well.
    pushbroom, 062 and JonJon78 Thank this.
  4. Don379
    Don379 Heavy Load Member
    714
    1,286
    Jan 7, 2021
    that would take alot of gasoline to contaminant 100 gallons of diesel. wouldnt it. the gas would just dissolve in that amount of diesle. So were talking what, 10 gallons of gas mixed in a diesel system that your talking about?
  5. Goodysnap
    3,771
    9,195
    Jul 12, 2017
    Much more common in the automotive/light truck world. Had a tanker in a few weeks ago. Id say it was 75% gas 25%Diesel. Towed in, barely running just enough to pull it into the shop bay. It only idled.
    pushbroom, Coffey and Don379 Thank this.
  6. Don379
    714
    1,286
    Jan 7, 2021
    thanks for clarifying. wow thats crazy
    Coffey Thanks this.
  7. Northern Nomad
    Northern Nomad Light Load Member
    166
    649
    Apr 1, 2020
    The frozen north
    Well, I have a similar story and I’ve been at it 20+ years. This past summer I was finishing my day, and I had to put oil in and also needed to fill up on DEF. At my work, you get both at the same door in the building. I have my hood up, and the cap off my DEF tank and so I start going about my business and then I suddenly realize that I’m putting oil in the DEF tank. I probably put a half gallon in before I realized it.
    Thankfully I knew enough to leave it be. Towed it into a bay, drained and flushed the DEF tank, and called it a wrap.
    But, it goes to show that it can happen to anyone, regardless of experience.
    Don379, Coffey and Goodysnap Thank this.
  8. AModelCat
    164,644
    Diesel in the DEF tank allegedly:
    Don379 Thanks this.
  9. Cattleman84
    Cattleman84 Road Train Member
    10,003
    71,358
    Nov 1, 2017
    The Sticks, Idaho
    I was about to say it would take quite a bit of gasoline... Used to be that 5 to 10 gallons of gasoline in 100 to 150 gallons of fuel was the tried and true anti-gel.
    Don379, BoxCarKidd and bzinger Thank this.
  10. Brandt
    Brandt Road Train Member
    4,624
    6,359
    Sep 17, 2012
    What about trying this, it remove water from tank and DEF is like 90% water. Seems like a very small amount of DEF is actually in the tanks
  11. Brandt
    4,624
    6,359
    Sep 17, 2012
    Howes Diesel treatment does the same thing and at every truck stop
